| » GE Wall Double Oven Top Oven Not Heating |
| By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use. |
Model Number: JTP27BA3BB Brand: GE Age: 5 - 10 years
Top oven just stopped working the other day out of the blue. Bottom Oven works just fine. Top oven (broil and bake elements) will not heat at all. Self Clean will not work either. The clock and display work just fine. When you press bake and set the temp and you can hear a click to start the elements but no heat (you hear a click under normal use even when it cycles the elements on and off while maintaining proper temp and upon startup). About another minute later another click and so forth. The display just shows 100 degrees, normal starting display temp.
Any advice is appreciated. Thanks in advance. |
| Display Modes | |
| Wall Oven ~ runaway heating element | thomland | Oven Repair (including Ranges and Cooktops) | 1 | 01-03-2008 10:37 AM |
| Whirlpool Double Wall Oven - Top Oven Not Working | bigguy | Oven Repair (including Ranges and Cooktops) | 0 | 11-15-2007 08:18 AM |
| Electric Double Wall Oven Warm, not Hot | jcrump55 | Oven Repair (including Ranges and Cooktops) | 2 | 11-12-2007 07:36 PM |
| Whirlpool Double Wall oven | choldca | Oven Repair (including Ranges and Cooktops) | 2 | 11-02-2007 01:02 PM |
| GE Electric Double Wall Oven won't bake or broil | tjp | Oven Repair (including Ranges and Cooktops) | 0 | 10-27-2007 09:06 AM |
