| » Kitchenaid Oven Door Removal |
Model Number: KEBS208 Brand: Kitchen Aid Age: 5 - 10 years
Both doors on my kitchenaid KEBS208DWH1 have broken inner glass. My oldest kid is home frm from college and broke both of them baking. I am having trouble removing the doors to replace the glass. Are there any instruction out there for removing the doors? I am not having much luck finding the instructions for these doors.
Thanks, -Joe Ads By Google Related Models |
Figured it out myself. There are holes in each hinge for removal pins. I substituted large nails for the pins. Insert a nail in each hinge when the door is open and the door will easily come out when it is almost closed.
I used framing nails that are a little larger than 1/8" in diameter and taped them in place with masking tape. I ground the points off the nails to provide extra margin on both sides of the hinge. |
removing the door is pretty easy..
there is a lever near the hinge, that gets placed towards you .. then the door should lift up and out.. as far as the glass... there is a bracket at the bottom and two screws at teh top corners.. they come out and then you can get to the glass .. now, getting the door back in i can't help you with... |
| Display Modes | |
| Oven Door Removal | fulfowi | Oven Repair (including Ranges and Cooktops) | 0 | 02-21-2010 01:59 PM |
| removal of oven door? | jimsdad | Oven Repair (including Ranges and Cooktops) | 1 | 01-08-2009 12:33 PM |
| Kitchenaid side by side ice-in-door facade removal | MikeBag58 | Refrigerator & Freezer Repair | 1 | 06-22-2008 12:30 AM |
| Door removal on Kitchenaid Dishwasher | Grey Eagle | Dishwasher Repair | 0 | 05-07-2008 07:01 AM |
| Oven door removal | suddeth | Oven Repair (including Ranges and Cooktops) | 0 | 01-24-2008 11:09 AM |
