I'd been on this forum before and received the response that I should replace two "fuse" parts in order to solve the problem of my oven heating elements not working: AP3189279 and AP3185961. However, I have two new problems: First, AP3189279 is a part to a different GE oven than mine. Second, when I do see the expanded diagram for the parts to my correct oven at Control panel replacement parts for General Electric ZET938SM1SS BUILT IN OVEN | AppliancePartsPros.com it lists two parts: AP3185961 and AP3885753, however, when I open up the control panel cover on my oven there is only one limit switche located there, not two, even though the diagram above shows there are supposed to be two. Help!!!!! What's going on here and which one should I use to replace the old one? :( Thanks! -Tom
