I need to replace the dual burner infinite switch. How do you access behind the control panel where the switch is located to swap out the switch? I see two screws at the front base of the control panel, but the heat shield visor blocks access to the screws.
Thanks,
Greg
Greg---I'm looking for help with the same problem. Have you found an answer?
