Whirlpool Electric double-oven. RBD275PDB14. Screen went black and made random beeping sounds. Light switch would work, but nothing else. This happened @ 3 years ago and we replaced control panel to fix. Ordered and installed control panel from here (AP3131916 8300429) today and no changes. Still black screen... Light button turns the lights on/off and is all that works as far as I can tell. Not sure where to go from here?? Any help would be greatly appreciated.
Never have run the self clean... The last time the oven worked the screen got real dim and eventually was black before it shut off. Then we never could get anything to show up on screen.
Try to turn the Bake on as you did before. Would it turn on even if the screen is blank?
I tried and nothing happened. All that I can tell that works is the light switch. All other buttons "beep" but screen is blank and nothing is coming on if I hit "Bake"
Groups: APP Team
