I bought this oven secondhand and need to totally clean it, can the oven door be easily removed and re=attached and can the oven bottom be taken out for easier cleaning?
Quote:can the oven door be easily removed The oven door removal process should be covered in the owner's manual. You can find owner's manual resources in the 'Home Service' section of my web site linked below. Quote:can the oven bottom be taken out for easier cleaning? *IF* removable, it wouldn't usually be removed for cleaning, just service... when necessary. JMO Dan O. www.Appliance411.com The Appliance Information Site=D~~~~~~
