Discuss
replacing interior glass
 in
Our interior glass shattered during the self-clean cycle used for the first time. Ge wanted $80 just to come
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » replacing interior glass
  #1 (permalink)
Old 01-10-2008, 02:20 PM
TomG TomG is offline
Junior Member
TomG is on a distinguished road
Default replacing interior glass
Model Number: JGBP85SEJ1SS   Brand: GE   Age: 1 - 5 years
Our interior glass shattered during the self-clean cycle used for the first time. Ge wanted $80 just to come out not including the part & labor. Then today they don't show up. So I'm thinking it can't be that hard.
GE says the part # is WB56K0020
Model # is JGBP85SEJ1SS
Before I try to order the part (not from GE I want to see if I can take the door apart myself. So I took the door off the hinge and placed it on the counter with the handle hanging over as has been suggested several times here. There are 4 screws on the bottom. I removed all 4 and I can sort of pry the outer & inner panels apart just slightly, but it looks like the panels are being held by the door handle. Assuming this is the right way to take apart the door to get to the glass, what kind of screw driver do I need to remove the door handle? It sure isn't a phillips
Tom
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-10-2008, 08:19 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi Tom,
Usually all screws are Phillips or Torx. If you can post some pictures, it might help.
According to the door break down diagram I do not think you have to remove the door handle.
- The APP part number for the inner door glass is AP2033716
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 01-11-2008, 09:14 AM
Junior Member
Default
Thanks, upon closer inspection of the door handle, you are correct, I can see the bolt that connects the handle to the outer panel. So the handle can stay on. The two screws on the inside panel must the torx heads, they have a star-like shape. I'll have to visit the hardware store and pick up a set of torx drill bits.
I assume I won't need to replace anything else?
  #4 (permalink)
Old 01-11-2008, 12:21 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
I do not think you would.
Good luck.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Replacing Glass Cooktop victordbeat Oven Repair (including Ranges and Cooktops) 2 07-29-2008 06:38 PM
Replacing the interior glass P/n:AP3008062 alain Oven Repair (including Ranges and Cooktops) 2 11-14-2007 09:37 AM
Replacing Glass Cooktop victordbeat Oven Repair (including Ranges and Cooktops) 0 11-04-2007 08:10 AM
Replacing the interior glass P/n:AP3008062 alain Oven Repair (including Ranges and Cooktops) 0 10-09-2007 03:36 PM
Replacing glass cooktop jennifer Oven Repair (including Ranges and Cooktops) 2 08-13-2007 12:46 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
