Discuss
Whirlpool oven sparking
 in
Hello! This morning, when I turned on the oven (to toast a bagel,if you wanted to know), it made
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Whirlpool oven sparking
  #1 (permalink)
Old 01-10-2008, 08:48 AM
MaryM MaryM is offline
Junior Member
MaryM is on a distinguished road
Unhappy Whirlpool oven sparking
Model Number: RF366BXDN 1   Brand: Whirlpool   Age: More than 10 years
Hello!
This morning, when I turned on the oven (to toast a bagel,if you wanted to know), it made this fizzling (shorting out)sound, and sparks flew out of the edges of the oven. I turned it off, unplugged it, looked inside, and found a little flaming blob on the bottom element. After the smoke cleared, I touched the little blob,and have decided that it is probably melted metal.
Is this a typical element burn-out sequence, or a symptom of something more -sinister-, and I should scrap the entire unit?
Thanks in advance,
MaryM
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-10-2008, 09:02 AM
TechnicianBrian's Avatar
TechnicianBrian TechnicianBrian is offline
Senior Expert
APP Volunteer
TechnicianBrian is on a distinguished road
Default
What you saw is a typical element failure. Get yourself a new element, turn the power off and remove the screws from the front element plate, pull it out carfully so you don't snag the wiring and replace it. Quick fix and you will be back to toasted bagels very soon.
__________________
TechnicianBrian
TechnicianBrian.com
Appliance Repair Blog
  #3 (permalink)
Old 01-10-2008, 09:23 AM
Junior Member
Default
Thanks!!!
M
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Double Wall Oven - Top Oven Not Working bigguy Oven Repair (including Ranges and Cooktops) 6 09-18-2008 10:03 AM
Thermador Cooktop Sparking Matt Schauer Oven Repair (including Ranges and Cooktops) 14 08-15-2008 06:35 PM
Range top keeps sparking jimotlnyc Oven Repair (including Ranges and Cooktops) 0 01-05-2008 10:10 AM
spark electro will not stop sparking barginhorse Oven Repair (including Ranges and Cooktops) 3 11-20-2007 02:42 PM
Whirlpool Gas Oven Bayardo Oven Repair (including Ranges and Cooktops) 1 11-05-2007 07:34 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
