2 Pages<12
#11 Posted : Thursday, January 17, 2008 9:54:43 AM(UTC)
This part is not too difficult to replace yourself.
The break down diagram will help you to find out the right way.
Good luck.
hulaboy
#12 Posted : Tuesday, January 22, 2008 8:12:59 PM(UTC)
hulaboy
Hello Gene
I plugged the new control board in, everything is working perfect.
Thank you very much, I couldn't have done it without your help.
Hulaboy.
#13 Posted : Wednesday, January 23, 2008 12:49:00 PM(UTC)
You are the man!
I'm glad you were able to fix it.
Oven Will not heat to temp. (Oven Repair (including Ranges and Cooktops))
by rtmeek 9/12/2022 12:32:58 PM(UTC)
Frigidaire FEFL79HQA Oven Will Not Heat (Broil or Bake) (Oven Repair (including Ranges and Cooktops))
by Allen_M 5/19/2022 8:57:30 AM(UTC)
Frigidaire - Oven will not heat up but burners work (Oven Repair (including Ranges and Cooktops))
by JohnGuerra 3/18/2020 12:45:12 PM(UTC)
Frigidaire gas oven will not heat (Oven Repair (including Ranges and Cooktops))
by HHG 9/6/2019 11:33:44 AM(UTC)
GE Profile Oven will not heat past 100, broiler works (Oven Repair (including Ranges and Cooktops))
by maribernj 2/16/2016 8:37:13 AM(UTC)
Oven will not heat (Oven Repair (including Ranges and Cooktops))
by couldcareless 11/11/2015 2:05:29 PM(UTC)
by davidwhop 8/31/2014 7:17:47 AM(UTC)
Double Wall Oven will not heat up (Oven Repair (including Ranges and Cooktops))
by jwmingus 11/12/2013 4:25:40 PM(UTC)
Frigidaire Left oven will not heat either element (Oven Repair (including Ranges and Cooktops))
by morang 9/27/2013 5:08:44 PM(UTC)
Thermador sc302t top oven will not heat (Oven Repair (including Ranges and Cooktops))
by bnastasi 6/9/2013 9:01:10 PM(UTC)
Lower and Upper Oven will not heat (Oven Repair (including Ranges and Cooktops))
by Igmike 4/22/2013 5:43:12 AM(UTC)
My Oven will not heat up on bake (Oven Repair (including Ranges and Cooktops))
by missy79 4/3/2013 9:59:06 AM(UTC)
Electrolux dual fuel range oven will not heat (Oven Repair (including Ranges and Cooktops))
by p.andrew 3/19/2013 8:47:44 AM(UTC)
by Pjcibulski 1/29/2013 2:00:44 PM(UTC)
Oven Will Not Heat (Oven Repair (including Ranges and Cooktops))
by badams1214 1/18/2013 12:14:24 PM(UTC)
2 Pages<12
