I have a viking professional stove 4 burner gas stove about 15 years old. Problems with door hinges. Repairs very expensive in past with repair person. I am trying to find where the model number is on the stove to order new hinges but unable to locate that. Any idea where to look for that? I see nothing on the door and I looked under to stove with a flash light. Do I need to pull out the stove?
I replaced mine a few years ago, and I think the model number was on the back. It was pretty easy to replace them, just undo the screw and jiggle them out, then replace the same way.
in the door opening under the control panel.
