Power surge at home during storm; cook top , clock. heat setting and etc.in display appear to be working, but when you set oven it will not ignite. Cook top ignites. Current to stove is available. Is there a reset in the head of the stove ? How to check if its the igniter bad or something else?
My Oven Will Not Heat Or Ignite Model # Fgb557ces-a
