| » Glass top stove element connections not quite the same |
Model Number: RF378LXKQ Brand: Whirlpool Age: 1 - 5 years
Recently, I had gotten a replacement element for my stove. Unfortunately, the connections are not quite the same. The wires in the stove have 2 large and 2 small connectors on the ends. The 2 bigger ones seem to be fairly straight forward as to where they would go on the new element, but I am having trouble with the 2 smaller ones. One of the small wires on the stove is always hot, and the other appears to go to the indicator once the element gets hot.
The markings on the new element have an "H" and a "S". Is the "H" for "hot" and the "S" for "sensor"? I would like to know so that I do not get this hooked up correctly without destroying it. Thanks. Ads By Google Related Models |
Just follow the element ribbon. If its a single element, it is a loop around the mold of the housing. That is where you 220V would connect to your S.U. switch. The other 2 should be to the Hot Suface Indicator. Try and find your wiring diagram in the bottom drawer to be sure.
| Display Modes | |
| oven element/broiler element not working stove top is | MD110772 | Oven Repair (including Ranges and Cooktops) | 3 | 07-05-2011 01:23 AM |
| Replacing a Whirlpool glass top stove element | RonChambers | Oven Repair (including Ranges and Cooktops) | 1 | 11-16-2009 06:26 PM |
| Maytag Glass Top Stove Element Wire Burnt off! | pmaldrum | Dishwasher Repair | 3 | 10-08-2009 05:02 PM |
| Maytag Glass Top Stove Element Wire Burnt off! | pmaldrum | Oven Repair (including Ranges and Cooktops) | 1 | 10-07-2009 04:52 PM |
| changing heat element on glass top stove | anthonywest | Oven Repair (including Ranges and Cooktops) | 0 | 03-08-2008 03:08 AM |
