octavio8
#1 Posted : Thursday, July 30, 2009 10:11:36 AM(UTC)
octavio8
The 9" left front burner (with simmer select) on my Kenmore model 79096212406 cooktop quit working. The "element on" light comes on but it doesn't heat up. I removed the burner and checked the element for continuity and it seems to be okay. All of the other burners are working just fine. Any suggestions?
Thanks in advance.
octavio8
#2 Posted : Thursday, July 30, 2009 12:05:59 PM(UTC)
octavio8
Problem solved!
I swapped out two of the element control infinite switches that are the same to see if just the switch was bad. Apparently there was a loose connection, because all of the elements are working correctly now. Glad I tested the continuity and the infinite switch before replacing the $120 element. :D
#3 Posted : Thursday, July 30, 2009 1:22:03 PM(UTC)
We are glad you were able to fix it with no cost repair. Good job.
