Discuss
Gas Burner seal
 in
I noticed on the parts diagram for this model of Range there is a spring called a Burner seal. I
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Gas Burner seal
  #1 (permalink)
Old 01-09-2008, 11:38 AM
vornato vornato is offline
Junior Member
vornato is on a distinguished road
Default Gas Burner seal
Model Number: SF360BEEW   Brand: Whirlpool   Age: More than 10 years
I noticed on the parts diagram for this model of Range there is a spring called a Burner seal. I wonder if this might cause the Burner not to ignite properly, if the spring is not positioned right from the venturi opening to the burner. Is the spring suppose to seal the burner and venturi. And would this cause the flame to start at the venturi shutter and gas valve if it dropped down from the burner, as I notice the instructions on this model call for the Burner seal to be positioned to the top of the venturi opening where it meets the burner. If this spring were to drop could it cause problems in the burner not igniting right. Oh well. Any help appreciated.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
dishwasher door seal bpb1brou Dishwasher Repair 4 11-20-2007 09:10 AM
Leaky seal romeroom Dishwasher Repair 0 11-19-2007 09:28 PM
Door Seal Wesley James Refrigerator & Freezer Repair 1 10-29-2007 05:53 PM
replace tub seal lhurt Washer Repair 4 10-08-2007 07:39 AM
Where does this gasket go? (seal replacement) g3_ultra Washer Repair 0 09-01-2007 11:09 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
