We moved into an apartment, & the existing Dacor oven door doesn't seem to close tightly and food takes way too long to cook. I was told that the door latch needs to be replaced. Attached is a photo of the door latch we removed, part #86166. We received part #AP4515776 which we were told is the direct replacement but looks different and wanted to confirm that this is correct. I realize that the new door latch may not fix the problem but hopefully it will. Does anyone think that the door issue might be something other than the latch, because as I continue research it seems that the latch is only relevant for cleaning but it doesn't work for that either. DSC attached the following image(s):
The problem you mentioned has nothing to do with the door latch. The door lats works only when you used the self clean mode. Otherwise the door is not latched. Most likely the cause of this problem is a broken/bend door hinges or bend door frame and/or inner door liner. The hinges can be replaced, but if the problem is with the door frame or door liner - it's not repairable. - The kit of the door hinges Part number: AP4366050
Thank you so much. How do I know where the problem lies, as it all looks fine. Hinges don't appear to be bent, and the door seems to be okay - I think. Could it be the door sealer?
If you can not see what caused the problem, then you probably have to call a pro for diagnosis. Guessing does not work and can be very expensive.
