Cooktop has 4 burners; two with simmer feature. one simmer burner has faulty behavior: Burner lights normally; simmer function seems to work. After a few minutes of normal use, the burner stops burning as if the thermal couple function failed. At that time the ignitor continues to spark and relight but gas stays off. What is the most probable cause.... just a new ignitor? or other part?
