The dual burner (right front) on my unit seems to heat to either HIGH or LOW temperature...no middle ground. What is the part I'd need to replace to fix this so that I can have the full range of temperature?
Do I need to replace the dual burner, or just the limiter, or BOTH? Or is it a different part entirely?
Thanks! BigDadu
