| » Surface Indicator Light stays ON/electric range |
Model Number: MER5530AAW Brand: Maytag Age: More than 10 years
One of my burners sparked and triggered my circuit breaker to turn it off. When I replaced the burner and fixed the wiring, this burner worked fine. However, one of the surface indicator lights that shows that one of the burners is on, never goes off now. If all the burners are not in use and are turned off, this light wll remain on. Is this dangerous and will it cause a fire? How do I fix this light so that it will function normally. Thank you for your help.
You have there a shorted out infinite switch (the one operates the replaced element).
For the large element use this one Part number: 7403P239-60 For the small one Part number: 7403P238-60 Here are the breakdown diagrams and Replacement parts for Maytag MER5530AAW RANGE- S/C F/S ELE | AppliancePartsPros.com Thank you. Post the results. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Quote:
Did you have any similar problems as the previous post? Please describe in a bit more details. Thank you. Simon.
__________________
| Display Modes | |
| Jenn-air Electric Range right-front element fails - hot indicator lamp stays on | jwbnyc | Oven Repair (including Ranges and Cooktops) | 62 | 11-07-2012 11:02 AM |
| surface indicator light stays on all the time | nolesman98 | Oven Repair (including Ranges and Cooktops) | 5 | 02-23-2012 05:33 AM |
| 1 Burner doesn't work, and hot surface indicator light stays on | ekleber | Oven Repair (including Ranges and Cooktops) | 6 | 02-04-2011 10:36 AM |
| hot surface indicator light stays on constantly | changty | Oven Repair (including Ranges and Cooktops) | 0 | 07-17-2010 05:07 PM |
| surface indicator light stays on | slomotion | Oven Repair (including Ranges and Cooktops) | 0 | 05-22-2008 10:30 AM |
