Discuss
tappan oven makes fluterring sound
 in
My tappan range w/oven below and above was purchased in 1994. The problem exist in the lower oven and is
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » tappan oven makes fluterring sound
  #1 (permalink)
Old 07-27-2009, 10:37 AM
Junior Member
Texman29 is on a distinguished road
Default tappan oven makes fluterring sound
Model Number: 72-3981-00/07   Brand: Tappan   Age: More than 10 years
My tappan range w/oven below and above was purchased in 1994. The problem exist in the lower oven and is of a Continuous Self-Cleaning type.
My problem is when turning this oven on it hesitates, I see however a reddish light thru the oven bottom slits. Then after 2 or 3 minutes I hear the puff of the gas igniting. It burns then but with a fluttering sound and in order to avoid any unfortunate consequences I turn it off.
Has anyone experienced similiar occurrances , or does someone know the cause of this behaviour - please let me know and thanks you'll Texman29
Ads By Google
Related Models
Frigidaire 72-3981-23-01 Tap(v2) / Gas Range
Frigidaire 72-3981-23-02 Tap(v2) / Gas Range
Frigidaire 72-3981-23-03 Tap(v4) / Gas Range
Frigidaire 72-3981-23-04 Tap(v2) / Gas Range
Frigidaire 72-3981-23-05 Tap(v2) / Gas Range
Frigidaire 72-3981-23-06 Tap(v4) / Gas Range
Frigidaire 72-3981-23-07 Tap(v2) / Gas Range
Frigidaire 72-3981-23-08 Tap(v2) / Gas Range
Frigidaire 72-3989-00-01 Tap(v1) / Gas Range
Frigidaire 72-3989-00-02 Tap(v4) / Gas Range
Frigidaire 72-3989-00-03 Tap(v1) / Gas Range
Frigidaire 72-3989-00-04 Tap(v1) / Gas Range
Frigidaire 72-3989-00-05 Tap(v4) / Gas Range
Frigidaire 72-3989-00-06 Tap(v7) / Gas Range
Frigidaire 72-3989-23-01 Tap(v2) / Gas Range
Frigidaire 72-3989-23-02 Tap(v5) / Gas Range
Frigidaire 72-3989-23-03 Tap(v2) / Gas Range
Frigidaire 72-3989-23-04 Tap(v2) / Gas Range
Frigidaire 72-3989-23-05 Tap(v5) / Gas Range
Frigidaire 72-3989-23-06 Tap(v8) / Gas Range
Frigidaire 72-3989-66-01 Tap(v3) / Gas Range
Frigidaire 72-3989-66-02 Tap(v6) / Gas Range
Frigidaire 72-3989-66-03 Tap(v3) / Gas Range
Frigidaire 72-3989-66-04 Tap(v3) / Gas Range
Frigidaire 72-3989-66-05 Tap(v6) / Gas Range
Frigidaire 72-3989-66-06 Tap(v9) / Gas Range
Frigidaire 72-4256-00-01 Tap(v1)
Frigidaire 72-4256-00-02 Tap(v3)
Frigidaire 72-4256-00-03 Tap(v5)
Frigidaire 72-4256-23-01 Tap(v2)
Frigidaire 72-4256-23-02 Tap(v4)
Frigidaire 72-4256-23-03 Tap(v6)
Frigidaire 72-7657-00-02 Tap(v7) / Gas Range
Frigidaire 72-7657-00-03 Tap(v7) / Gas Range
Frigidaire 72-7657-00-04 Tap(v10) / Gas Range
Frigidaire 72-7657-00-05 Tap(v4) / Gas Range
Frigidaire 72-7657-00-06 Tap(v10) / Gas Range
Frigidaire 72-7657-00-07 Tap(v4) / Gas Range
Frigidaire 72-7657-00-08 Tap(v4) / Gas Range
Frigidaire 72-7657-00-09 Tap(v10) / Gas Range
Frigidaire 72-7657-23-01 Tap(v8) / Gas Range
Frigidaire 72-7657-23-02 Tap(v11) / Gas Range
Frigidaire 72-7657-23-03 Tap(v8) / Gas Range
Frigidaire 72-7657-23-04 Tap(v11) / Gas Range
Frigidaire 72-7657-23-05 Tap(v5) / Gas Range
Frigidaire 72-7657-23-06 Tap(v11) / Gas Range
Frigidaire 72-7657-23-07 Tap(v5) / Gas Range
Frigidaire 72-7657-23-08 Tap(v5) / Gas Range
Frigidaire 72-7657-23-09 Tap(v11) / Gas Range
Frigidaire 72-7657-66-01 Tap(v9) / Gas Range
Frigidaire 72-7657-66-02 Tap(v12) / Gas Range
Frigidaire 72-7657-66-03 Tap(v9) / Gas Range
Frigidaire 72-7657-66-04 Tap(v12) / Gas Range
Frigidaire 72-7657-66-05 Tap(v6) / Gas Range
Frigidaire 72-7657-66-06 Tap(v12) / Gas Range
Frigidaire 72-7657-66-07 Tap(v6) / Gas Range
Frigidaire 72-7657-66-08 Tap(v6) / Gas Range
Frigidaire 72-7657-66-09 Tap(v12) / Gas Range
Frigidaire 72-7977-00-01 Tap(v13) / Gas Range
Frigidaire 72-7977-00-02 Tap(v16) / Gas Range
Frigidaire 72-7977-00-03 Tap(v19) / Gas Range
Frigidaire 72-7977-00-04 Tap(v22) / Gas Range
Frigidaire 72-7977-00-05 Tap(v7) / Gas Range
Frigidaire 72-7977-00-06 Tap(v10) / Gas Range
Frigidaire 72-7977-00-07 Tap(v4) / Gas Range
Frigidaire 72-7977-00-08 Tap(v10) / Gas Range
Frigidaire 72-7977-00-09 Tap(v4) / Gas Range
Frigidaire 72-7977-00-10 Tap(v10) / Gas Range
Frigidaire 72-7977-23-01 Tap(v14) / Gas Range
Frigidaire 72-7977-23-02 Tap(v17) / Gas Range
Frigidaire 72-7977-23-03 Tap(v20) / Gas Range
Frigidaire 72-7977-23-04 Tap(v23) / Gas Range
Frigidaire 72-7977-23-05 Tap(v8) / Gas Range
Frigidaire 72-7977-23-06 Tap(v11) / Gas Range
Frigidaire 72-7977-23-07 Tap(v5) / Gas Range
Frigidaire 72-7977-23-09 Tap(v5) / Gas Range
Frigidaire 72-7977-23-10 Tap(v11) / Gas Range
Frigidaire 72-7977-66-01 Tap(v15) / Gas Range
Frigidaire 72-7977-66-02 Tap(v18) / Gas Range
Frigidaire 72-7977-66-03 Tap(v21) / Gas Range
Frigidaire 72-7977-66-04 Tap(v24) / Gas Range
Frigidaire 72-7977-66-05 Tap(v9) / Gas Range
Frigidaire 72-7977-66-06 Tap(v12) / Gas Range
Frigidaire 72-7977-66-07 Tap(v6) / Gas Range
Frigidaire 72-7977-66-08 Tap(v12) / Gas Range
Frigidaire 72-7977-66-09 Tap(v6) / Gas Range
Frigidaire 72-7977-66-10 Tap(v12) / Gas Range
Frigidaire 72-7989-00-01 Tap(v7) / Gas Range
Frigidaire 72-7989-00-02 Tap(v10) / Gas Range
Frigidaire 72-7989-00-03 Tap(v4) / Gas Range
Frigidaire 72-7989-23-02 Tap(v11) / Gas Range
Frigidaire 72-7989-23-03 Tap(v5) / Gas Range
Frigidaire 72-7989-66-01 Tap(v9) / Gas Range
Frigidaire 72-7989-66-02 Tap(v12) / Gas Range
Frigidaire 72-7989-66-03 Tap(v6) / Gas Range
Maytag 72355-207 Misc / Accessory
Hoover 728 Frigidaire/refrigerator
Frigidaire 73-3751-00-01 Tap(v1) / Electric Range
Frigidaire 73-3751-00-02 Tap(v1) / Electric Range
Frigidaire 73-3751-00-03 Tap(v1) / Electric Range
Frigidaire 73-3751-00-04 Tap(v2) / Electric Range
Frigidaire 73-3751-23-01 Tap(v2) / Electric Range
Frigidaire 73-3751-23-02 Tap(v2) / Electric Range
Frigidaire 73-3751-23-03 Tap(v3) / Electric Range
Frigidaire 73-3751-23-04 Tap(v4) / Electric Range
Frigidaire 73-3751-66-01 Tap(v3) / Electric Range
Frigidaire 73-3751-66-02 Tap(v3) / Electric Range
Frigidaire 73-3757-00-01 Tap(v1) / Electric Range
Frigidaire 73-3757-00-02 Tap(v4) / Electric Range
Frigidaire 73-3757-00-03 Tap(v7) / Electric Range
Frigidaire 73-3757-00-04 Tap(v10) / Electric Range
Frigidaire 73-3757-00-05 Tap(v1) / Electric Range
Frigidaire 73-3757-00-06 Tap(v4) / Electric Range
Frigidaire 73-3757-00-07 Tap(v7) / Electric Range
Frigidaire 73-3757-00-08 Tap(v1) / Electric Range
Frigidaire 73-3757-00-09 Tap(v1) / Electric Range
Frigidaire 73-3757-23-01 Tap(v2) / Electric Range
Frigidaire 73-3757-23-02 Tap(v5) / Electric Range
Frigidaire 73-3757-23-03 Tap(v8) / Electric Range
Frigidaire 73-3757-23-04 Tap(v11) / Electric Range
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
whirlpool oven sometimes heats/sometimes doesn't/makes awful sound when ignites crazyoven Oven Repair (including Ranges and Cooktops) 3 07-02-2009 04:06 PM
makes a humming sound when on angel4022 Oven Repair (including Ranges and Cooktops) 1 01-27-2009 11:10 AM
Old Tappan Microwave makes no heat. gopherrabbit Microwave Repair 2 01-12-2009 09:07 PM
Oven won't heat to temp, makes clicking sound gilligan229 Oven Repair (including Ranges and Cooktops) 0 12-22-2008 09:13 PM
Freezer fan makes a rattleing sound Ben Tym Refrigerator & Freezer Repair 6 08-10-2007 02:54 PM
