Hi, I have a problem in that the oven heats up to the proper temperature but won't maintain that temperature. It doesn't seem to to on again after the initial heat up. It was purchased at Ikea in the "as is" section and therefore has no warranty. Any ideas would be appreciated, Than you, Will
Could be a faulty temp sensor or faulty relay on the control board.
