I need help- Trying to repair my Thermador extra low burner, but my repair guy can't get one of the burners apart -therefore can't access and repair my extra low burner. I guess he could core out the center of the burner and try to remove the burner that way.. I have already had two service calls on this. I just put in new countertops and have the downdraft exterior blower connected to this cooktop. Is there any hope for me?
Groups: APP Team
To take out burner base and plate you need to uncrew the injector sleeve part number AP2821735.You have to use a socket head 20mm (or 22mm) Before doing anything i recomend to apply some water around injector sleeve using a sponge.If the sleeve already damaged reshape it using a Drimel tool and then use smaller socket.Good luck.
Thanks-- if that does not work, I guess I will have to core out the brass bolt. right? I appreciate any advice.
Groups: APP Team
Yes you are right. Good luck.
