I need to replace the right front double burner. Only the inner burner is working. How do I remove the cooktop and what is the part number that I need to replace it?
Groups: APP Team
In order to raise the glass top look under the front end of it.You should see 2 vertical screws.Take them out and raise the top.If you don't see screws then using the potty knife undo two clips (one on each side). The burner itself is held by two screws.Mark all the wires and position of screws.
Part number for the double burner AP4009116
[PART][/PART]
