HI i'm sorry to post this if it is already up, but im having some issues that are not mentioned. so i thought i would ask first. i just changed my spark module today because in these threads i see it should be pushing 8-18 volts to the distibutor. i was getting 54 volts from my old one. now the new one is exactly the same 54 volts from both broiler and oven. way off from the 8-18 i keep reading. also, thats at the same time, meaning when the oven is preheating both broiler and oven lines are at 54 volts. any ideas? so i checked the resistance of the distribution valve and might not understanding how to measure? my meter never stops moving from below 218 to above 218 ohms, so i dont know if it is bad. dont want to spend more money when i cant seem to get the right ohms or voltages from what i read. wife is getting upset since this oven wasnt all that cheap. help!!!!!:mad:
Originally Posted by: hooksindo Whirlpool super capacity gas range oven wont light? Laser pointer yes, sorry. will not light, i hear 2 clicks but not sure if thats the ignitor or something else. no gas smell
