I orderd new gas valve part #5303208499. installed it and there is to much flame in the oven. I'am on LP gas is there a orfice that needs to be changed over from natural gas. and how do i do that. I changed the nipple on the valve that did not work. old valve works but has a small gas leak when oven is off, new valve took care of that problem, but there is to much flame.Broiler works fine. thanks
