| » Right fr and rear control triggers igniter for left rear burner |
Model Number: 326.72201881 Brand: Kenmore Age: 1 - 5 years
This gas stove has left front and rear burners that work fine. When you turn their handles, the igniter works for each one.
However, when trying to ignite the right front or rear, the left rear igniter tries to ignite, not the ones on the right. Any one ever had this problem? This is a used stove in otherwise very good condition I picked up and trying to use. Oven and broiler work well. Correction: Model is 362.72201881 Related Models Last edited by edmccar : 07-24-2009 at 07:35 AM. Reason: UPDATE. |
Quote:
Quote:
Quote:
JMO Dan O. www.Appliance411.com The Appliance Information Site =D~~~~~~ |
Thanks for your input Dan O.
I corrected the model number. However, on another stove I looked at, only the igniter for the burner I am trying to light is the one that sparks. Even on this stove, on the left side, only the burner that I am trying to light is the only one that sparks. |
Quote:
Quote:
Quote:
LINK > Kenmore 362.72201891 Spark Module The spark module has one power input and 4 power outputs, one to each burner (commonly referred to as a '4+0 spark module' - the 4 being the number of surface burner outputs). JMO Dan O. www.Appliance411.com The Appliance Information Site =D~~~~~~ Last edited by Dan O. : 07-25-2009 at 01:14 PM. |
| Display Modes | |
| Kenmore right rear simmer burner issue | pfp888 | Oven Repair (including Ranges and Cooktops) | 1 | 01-29-2009 05:43 PM |
| Rear Xlo burner inop | viz | Oven Repair (including Ranges and Cooktops) | 0 | 11-14-2008 11:04 AM |
| Rear bearing on Frigidaire | Kenworth | Washer Repair | 6 | 08-20-2008 09:27 PM |
| Frigidaire Electric Oven Rear burner light wont go off | seagullgeneral | Oven Repair (including Ranges and Cooktops) | 1 | 12-14-2007 05:58 PM |
| Rear Tub Bearing | Justncase | Washer Repair | 5 | 08-08-2007 10:54 PM |
