Discuss
Jenn Air Cooktop problem
 in
My grill element won't light, even with a match. It has been removed, cleaned, over cleaner cleaned, blown out with
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Jenn Air Cooktop problem
  #1 (permalink)
Old 07-21-2009, 05:47 PM
Junior Member
imintherockies is on a distinguished road
Default Jenn Air Cooktop problem
Model Number: CG206B   Brand: Jenn-Air   Age: More than 10 years
My grill element won't light, even with a match. It has been removed, cleaned, over cleaner cleaned, blown out with air, etc. When removed, the stubs will light with a match. When I remove the tubes from the element with a slot screwdriver and place them over the stubs, the also light with a match. Completely assembled, it will not light. Any suggestions will help. Thanks so much. Dave
Ads By Google
Related Models
Jenn-Air CG206B Surface Unit - Ddraft Gas
Jenn-Air CG206B-C Surface Unit - Ddraft Gas
Jenn-Air CG206B-E Surface Unit - Ddraft Gas
Jenn-Air CG206L Surface Unit - Ddraft Gas
Jenn-Air CG206L-C Surface Unit - Ddraft Gas
Jenn-Air CG206S Surface Unit - Ddraft Gas
Jenn-Air CG206S-C Surface Unit - Ddraft Gas
Jenn-Air CG206W Surface Unit - Ddraft Gas
Frigidaire CG20A Frg(v1) / Chest Freezer
Frigidaire CG20B Frg(v2) / Chest Freezer
Whirlpool CG2101XMW0
Whirlpool CG2101XMW1
Frigidaire CG23A Frg(v1) / Chest Freezer
Frigidaire CG23B Frg(v2) / Chest Freezer
Frigidaire CG240SP2D1 Kel(v8) / Gas Range
Frigidaire CG240SP2D2 Frg(v2) / Gas Range
Frigidaire CG240SP2D3 Frg(v2) / Gas Range
Frigidaire CG240SP2L02 Frg(v2) / Gas Range
Frigidaire CG240SP2W1 Tap(v4) / Gas Range
Frigidaire CG240SP2W2 Frg(v1) / Gas Range
Frigidaire CG240SP2W3 Frg(v1) / Gas Range
Amana CG2412 Dryer - Gas
Whirlpool CG2501XMW0
Whirlpool CG2501XMW1
Whirlpool CG2951XSW0
Whirlpool CG2951XSW1
Whirlpool CG2951XSW2
Whirlpool CG2951XSW3
Whirlpool CG2951XYG0
Whirlpool CG2951XYG1
Whirlpool CG2951XYG2
Whirlpool CG2951XYG3
Whirlpool CG2951XYN0
Whirlpool CG2951XYN1
Whirlpool CG2951XYN2
Whirlpool CG2951XYN3
Whirlpool CG2951XYW0
Whirlpool CG2951XYW1
Whirlpool CG2951XYW2
Whirlpool CG2951XYW3
Whirlpool CG2951XYW4
Thermador CG29E
Thermador CG29F
Thermador CG29FLP
Frigidaire CG300SP2D1 Frg(v2) / Gas Range
Frigidaire CG300SP2D2 Frg(v2) / Gas Range
Frigidaire CG300SP2D3 Frg(v2) / Gas Range
Frigidaire CG300SP2D5 Frg(v4) / Gas Range
Frigidaire CG300SP2W1 Tap(v4) / Gas Range
Frigidaire CG300SP2W2 Frg(v1) / Gas Range
Frigidaire CG300SP2W3 Frg(v1) / Gas Range
Frigidaire CG300SP2W5 Frg(v3) / Gas Range
Frigidaire CG300SP2WD01 Kel(v14) / Gas Range
Frigidaire CG300SP2WH01 Frg(v3) / Gas Range
Frigidaire CG300SP2WJ01 Kel(v15) / Gas Range
Frigidaire CG300SP2WL01 Frg(v2) / Gas Range
Frigidaire CG300SP2WW01 Frg(v1) / Gas Range
Frigidaire CG300SP2WY01 Gib(v9) / Gas Range
Frigidaire CG300SP2Y1 Frg(v3) / Gas Range
Frigidaire CG301SP2D03 Frg(v4) / Gas Range
Frigidaire CG301SP2D1 Frg(v2) / Gas Range
Frigidaire CG301SP2D2 Frg(v2) / Gas Range
Frigidaire CG301SP2D4 Frg(v2) / Gas Range
Frigidaire CG301SP2W1 Tap(v4) / Gas Range
Frigidaire CG301SP2W2 Frg(v1) / Gas Range
Frigidaire CG301SP2W3 Frg(v3) / Gas Range
Frigidaire CG301SP2W4 Frg(v1) / Gas Range
Frigidaire CG301SP2WD01 Kel(v14) / Gas Range
Frigidaire CG301SP2WH01 Frg(v3) / Gas Range
Frigidaire CG301SP2WJ01 Kel(v15) / Gas Range
Frigidaire CG301SP2WL01 Frg(v2) / Gas Range
Frigidaire CG301SP2WW01 Frg(v1) / Gas Range
Frigidaire CG301SP2WY01 Gib(v9) / Gas Range
Frigidaire CG301SP2Y1 Frg(v3) / Gas Range
Crosley CG3100PPA Range - F/s Std Gas
Crosley CG3100PPW Range - F/s Std Gas
Crosley CG3110PPA Range - F/s Std Gas
Crosley CG3110PPW Range - F/s Std Gas
Crosley CG3110PRA Range - F/s Std Gas
Crosley CG3110PRV Range - F/s Std Gas
Crosley CG3110PRW Range - F/s Std Gas
Crosley CG31200ADQ Range - F/s Std Gas
Crosley CG31200ADV Range - F/s Std Gas
Crosley CG31200ADW Range - F/s Std Gas
Crosley CG31200BDQ Range - F/s Std Gas
Crosley CG31200BDV Range - F/s Std Gas
Crosley CG31200BDW Range - F/s Std Gas
Crosley CG3120SPA Range - F/s Std Gas
Crosley CG3120SPN Range - F/s Std Gas
Crosley CG3120SPW Range - F/s Std Gas
Crosley CG3120SRA Range - F/s Std Gas
Crosley CG3120SRW Range - F/s Std Gas
Crosley CG3131WRA Range - F/s Std Gas
Crosley CG3131WRW Range - F/s Std Gas
Crosley CG3131WUA Range - F/s Std Gas
Crosley CG3131WUW Range - F/s Std Gas
Crosley CG3131XRA Range - F/s Std Gas
Crosley CG3131XRW Range - F/s Std Gas
Crosley CG3131XUA Range - F/s Std Gas
Crosley CG3131XUW Range - F/s Std Gas
Crosley CG3137XUA Range - F/s Std Gas
Crosley CG3137XUW Range - F/s Std Gas
Crosley CG31400ADW Range - F/s Std Gas
Crosley CG31600ADB Range - F/s Std Gas
Crosley CG31600ADQ Range - F/s Std Gas
Crosley CG31600ADV Range - F/s Std Gas
Crosley CG3177VRV Range - F/s Std Gas
Crosley CG3177VUV Range - F/s Std Gas
Crosley CG3177XRA Range - F/s Std Gas
Crosley CG3177XRW Range - F/s Std Gas
Crosley CG3177XUA Range - F/s Std Gas
Crosley CG3177XUW Range - F/s Std Gas
Crosley CG3231XRA Range - F/s Cont Clean Gas
Crosley CG3231XRW Range - F/s Cont Clean Gas
Crosley CG3231XUA Range - F/s Cont Clean Gas
Crosley CG3231XUW Range - F/s Cont Clean Gas
Crosley CG34300ADA Range - S/c F/s Gas
Crosley CG34300ADT Range - S/c F/s Gas
Crosley CG34300ADW Range - S/c F/s Gas
Crosley CG3432SRA Range - S/c F/s Gas
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Old Jenn-Air Cooktop fredringwald Oven Repair (including Ranges and Cooktops) 3 06-19-2009 03:04 PM
jenn-air cooktop problem carbuff Oven Repair (including Ranges and Cooktops) 4 10-30-2008 06:29 PM
jenn air cooktop valves dmmabee Oven Repair (including Ranges and Cooktops) 1 01-28-2008 06:11 PM
Jenn Air Electric Cooktop Mike Gallagher Oven Repair (including Ranges and Cooktops) 0 11-30-2007 06:48 PM
