The Cooking Element is working for the stove, but the oven is not working. Anyone has any idea? Thanks in advance!
I could not find parts for this unit the following is the closest I could get. Replacement parts for REE33301 models | AppliancePartsPros.comSo to see if parts are available you will have to contact the parts reps at AppliancePartsPros. I was able to find a wiring diagram for it, see the attachment. You will see in the wiring diagram that the elements do have a safety thermostat I think this is Item 8 in Section 4 of the parts listing but do not know where it is located. They are usually attached to the outside of the oven housing on the back. Also it shows either a switch or a circuit board attached to L1 of the oven control that would kill power to the elements but I could not find them in the parts breakdown. The unit may not be repairable if the parts listing I found is a close match to yours as most parts look to be obsolete. |
THIS FORUM IS DEAD!!!!!!! |
