I have a Modern Maid FDO180-2D with a blown fuse. The original part number is 67593. This is no longer available. Can this fuse be replaced with a standard Time-Delay 125 volt, 15 amp fuse (SL-15) or is a special fuse required?
You can use it, but you have to replace the fuse holder too.
