Maytag electric oven Model # MEW5530DDB has a clicking noise coming from around the control panel, the noise sounds light a electric fence clicking, it will stop if you press and turn on the oven light or open the door and the oven light comes on.
This oven has been used less than 100 hours. Turned power off and on still no change. The oven works perfect except for this clicking noise!
I removed the light bulb, and pressed and turned on the oven light on the panel, the clicking noise is gone. So now I don't have a oven light, but I don't have a clicking sound either.
Would this be the control panel, the control module or something else? Thanks for the help:)
