Discuss
Whirlpool Double Oven Won't Turn Off
 in
A couple of weeks ago I got the error code E6F2. Called in the Whirlpool repair guy and he said
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Whirlpool Double Oven Won't Turn Off
  #1 (permalink)
Old 02-07-2012, 09:22 PM
Junior Member
Bobmmm is on a distinguished road
Default Whirlpool Double Oven Won't Turn Off
Model Number: RBD275   Brand: Whirlpool   Age: 5 - 10 years
A couple of weeks ago I got the error code E6F2. Called in the Whirlpool repair guy and he said the electronic control board was bad. Also said the part was not made any more. I got the board repaired, and installed the repaired board. Now everything seems to work except the oven won't turn off. I have to kill it with the breaker. Could the repair be faulty or is the problem now the keypad?
Bob
Ads By Google
Related Models
Whirlpool RBD275PDB1
Whirlpool RBD275PDB10
Whirlpool RBD275PDB11
Whirlpool RBD275PDB12
Whirlpool RBD275PDB13
Whirlpool RBD275PDB14 27" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD275PDB15 27" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD275PDB2
Whirlpool RBD275PDB3
Whirlpool RBD275PDB4
Whirlpool RBD275PDB6
Whirlpool RBD275PDB7
Whirlpool RBD275PDB8
Whirlpool RBD275PDB9
Whirlpool RBD275PDQ1
Whirlpool RBD275PDQ10
Whirlpool RBD275PDQ11
Whirlpool RBD275PDQ12
Whirlpool RBD275PDQ13
Whirlpool RBD275PDQ14 27" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD275PDQ15 27" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD275PDQ2
Whirlpool RBD275PDQ3
Whirlpool RBD275PDQ4
Whirlpool RBD275PDQ6
Whirlpool RBD275PDQ7
Whirlpool RBD275PDQ8
Whirlpool RBD275PDQ9
Whirlpool RBD275PDS12
Whirlpool RBD275PDS14 27" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD275PDS15 27" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD275PDT10
Whirlpool RBD275PDT11
Whirlpool RBD275PDT12
Whirlpool RBD275PDT13
Whirlpool RBD275PDT14 27" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD275PDT15 27" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD275PDT8
Whirlpool RBD275PDT9
Whirlpool RBD275PRB00 24" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD275PRQ00 24" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD275PRS00 24" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD275PRS01 27" Built - in Electric Double Oven Convection - Upper Self - Clean (gold Line)
Whirlpool RBD275PRT00 24" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD276PDB1
Whirlpool RBD276PDB10
Whirlpool RBD276PDB11
Whirlpool RBD276PDB12
Whirlpool RBD276PDB2
Whirlpool RBD276PDB4
Whirlpool RBD276PDB6
Whirlpool RBD276PDB7
Whirlpool RBD276PDB8
Whirlpool RBD276PDB9
Whirlpool RBD276PDQ1
Whirlpool RBD276PDQ10
Whirlpool RBD276PDQ11
Whirlpool RBD276PDQ12
Whirlpool RBD276PDQ2
Whirlpool RBD276PDQ4
Whirlpool RBD276PDQ6
Whirlpool RBD276PDQ7
Whirlpool RBD276PDQ8
Whirlpool RBD276PDQ9
Whirlpool RBD277PDB1
Whirlpool RBD277PDB2
Whirlpool RBD277PDB4
Whirlpool RBD277PDQ1
Whirlpool RBD277PDQ2
Whirlpool RBD277PDQ4
Whirlpool RBD305PDB1
Whirlpool RBD305PDB10
Whirlpool RBD305PDB11
Whirlpool RBD305PDB12
Whirlpool RBD305PDB13
Whirlpool RBD305PDB14 30" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD305PDB15 30" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD305PDB2
Whirlpool RBD305PDB3
Whirlpool RBD305PDB4
Whirlpool RBD305PDB6
Whirlpool RBD305PDB7
Whirlpool RBD305PDB8
Whirlpool RBD305PDB9
Whirlpool RBD305PDQ1
Whirlpool RBD305PDQ10
Whirlpool RBD305PDQ11
Whirlpool RBD305PDQ12
Whirlpool RBD305PDQ13
Whirlpool RBD305PDQ14 30" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD305PDQ15 30" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD305PDQ2
Whirlpool RBD305PDQ3
Whirlpool RBD305PDQ4
Whirlpool RBD305PDQ6
Whirlpool RBD305PDQ7
Whirlpool RBD305PDQ8
Whirlpool RBD305PDQ9
Whirlpool RBD305PDS12
Whirlpool RBD305PDS14 30" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD305PDS15 30" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD305PDT11
Whirlpool RBD305PDT12
Whirlpool RBD305PDT13
Whirlpool RBD305PDT14 30" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD305PDT15 30" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD305PRB00 24" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD305PRQ00 24" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD305PRS00 24" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD305PRT00 24" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD306PDB1
Whirlpool RBD306PDB10
Whirlpool RBD306PDB11
Whirlpool RBD306PDB12
Whirlpool RBD306PDB13
Whirlpool RBD306PDB14 30" Built - in Electric Double Oven Self - Clean Upper and Lower Ovens
Whirlpool RBD306PDB15 30" Built - in Electric Double Oven Self - Clean Upper and Lower Ovens
Whirlpool RBD306PDB2
Whirlpool RBD306PDB4
Whirlpool RBD306PDB6
  #2 (permalink)
Old 02-07-2012, 09:26 PM
abadfish66's Avatar
Senior Expert
APP Volunteer
abadfish66 is a glorious beacon of light
Default
I would guess the repair being faulty. The relay that controls the heat is stuck in the on position instead of cycling on and off.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool double oven bubbered Oven Repair (including Ranges and Cooktops) 1 10-29-2011 01:38 AM
Double Oven and controls wont turn on albert houde Oven Repair (including Ranges and Cooktops) 0 09-03-2011 10:09 AM
Whirlpool double oven bm771@hotmail.com Oven Repair (including Ranges and Cooktops) 1 11-22-2010 01:23 PM
whirlpool double oven, only beeps, no display, does not turn on umairs123 Oven Repair (including Ranges and Cooktops) 0 02-15-2010 07:17 AM
Whirlpool Double Wall Oven - Top Oven Not Working bigguy Oven Repair (including Ranges and Cooktops) 6 09-18-2008 09:03 AM
