Appliance Repair Forum
-   Oven Repair (including Ranges and Cooktops) (http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/)
-   -   Whirlpool Double Oven Won't Turn Off (http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/413503-whirlpool-double-oven-wont-turn-off.html)
Bobmmm 02-07-2012 09:22 PM
A couple of weeks ago I got the error code E6F2. Called in the Whirlpool repair guy and he said the electronic control board was bad. Also said the part was not made any more. I got the board repaired, and installed the repaired board. Now everything seems to work except the oven won't turn off. I have to kill it with the breaker. Could the repair be faulty or is the problem now the keypad?
Bob:mad:
abadfish66 02-07-2012 09:26 PM
I would guess the repair being faulty. The relay that controls the heat is stuck in the on position instead of cycling on and off.
