Discuss
Jenn-Air Oven F0 code
 in
Our oven stopped working and has a 'F0' code that will not clear. I've shut off power and it worked
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Jenn-Air Oven F0 code
  #1 (permalink)
Old 07-20-2009, 09:46 AM
Junior Member
mcorneal is on a distinguished road
Default Jenn-Air Oven F0 code
Model Number: D156W   Brand: Jenn-Air   Age: More than 10 years
Our oven stopped working and has a 'F0' code that will not clear. I've shut off power and it worked again for about 20 seconds but the F0 reappeared and it won't reset again. One line of advice is to replace the timer (available-$197), but another says that it may be the touch pad (no longer available). I hate to buy the timer (non-returnable) only to find it's the touch pad. Any advice?
Ads By Google
Related Models
Jenn-Air D156W Range - S/c D/i Ele
Amana D16 Freezer - Vertical
Amana D16C Freezer - Vertical
Amana D16L Freezer - Vertical
Amana D18 Freezer - Vertical
Amana D18B Freezer - Vertical
Amana D18E Freezer - Vertical
Amana D20 Freezer - Vertical
Whirlpool D200
Amana D23 Freezer - Vertical
Amana D23A Freezer - Vertical
Amana D23B Freezer - Vertical
Amana D25 Freezer - Vertical
Whirlpool D25A0
Whirlpool D25A1
Whirlpool D25A2
Whirlpool D25B0
Whirlpool D300
Frigidaire D3000 Gib(v1) / Food Disposer
Frigidaire D3001 Gib(v2) / Food Disposer
Whirlpool D30A0
Whirlpool D30A1
Whirlpool D30A2
Whirlpool D30A3
Whirlpool D30B0
Maytag D31100PAAL Range - F/s Std Gas
Maytag D31100PATL Range - F/s Std Gas
Maytag D31100PAWL Range - F/s Std Gas
Maytag D31100SAAL Range - F/s Std Gas
Maytag D31100SAWL Range - F/s Std Gas
International D31103SAAL Range - F/s Std Gas
International D31103SAWL Range - F/s Std Gas
International D3110PRALT Range - F/s Std Gas
International D3110PRWLT Range - F/s Std Gas
Maytag D31111WAAL Range - F/s Std Gas
Maytag D31111WAWL Range - F/s Std Gas
Maytag D31113XAAL Range - F/s Std Gas
Maytag D31113XATL Range - F/s Std Gas
Maytag D31113XAWL Range - F/s Std Gas
International D3120SRALT Range - F/s Std Gas
International D3120SRWLT Range - F/s Std Gas
International D3121WTALT Range - F/s Std Gas
International D3121WTWLT Range - F/s Std Gas
International D3121XTALT Range - F/s Std Gas
International D3121XTWLT Range - F/s Std Gas
International D3167XRALT Range - F/s Std Gas
International D3167XRWLT Range - F/s Std Gas
International D3167XUALT Range - F/s Std Gas
International D3167XUWLT Range - F/s Std Gas
International D3167XVALT Range - F/s Std Gas
International D3167XVWLT Range - F/s Std Gas
Maytag D31FA-7-D Range - F/s Std Gas
Maytag D31FK-7-D Range - F/s Std Gas
Maytag D31FN-7-D Range - F/s Std Gas
Maytag D31FY-7-D Range - F/s Std Gas
Amana D396151 Misc / Accessory
Whirlpool D400
Whirlpool D401
Whirlpool D40A0
Whirlpool D40A1
Whirlpool D40A2
Whirlpool D40A3
Whirlpool D40B0
Whirlpool D500
Frigidaire D5000 Gib(v3) / Food Disposer
Whirlpool D50A0
Whirlpool D50A1
Whirlpool D50A2
Whirlpool D50B0
Whirlpool D5257X2
Whirlpool D5257^2
Frigidaire D5500 Gib(v1) / Food Disposer
Frigidaire D5501 Gib(v2) / Food Disposer
Hoover D6047 Undercounter Dishwasher
Hoover D6047-2
Hoover D6047-5
Hoover D6047-6
Whirlpool D6757X0
Whirlpool D6757X1
Whirlpool D6757^0
Whirlpool D6757^1
Amana D70221-1 Misc / Accessory
Amana D70368-1 Misc / Accessory
Amana D70368-9 Misc / Accessory
Frigidaire D7501 Gib(v3) / Food Disposer
Whirlpool D7507W0
Whirlpool D7507^0
Amana D7824702 Misc / Accessory
International D8210PA-L Surface Unit - Gas
International D8210PT-L Surface Unit - Gas
International D8210PW-L Surface Unit - Gas
International D8210PY-L Surface Unit - Gas
International D8241RA-L Surface Unit - Gas
International D8241RT-L Surface Unit - Gas
International D8241RW-L Surface Unit - Gas
International D8241RY-L Surface Unit - Gas
Maytag D8320PA-L Surface Unit - Ddraft Gas
Maytag D8320PW-L Surface Unit - Ddraft Gas
International D8320TA-L Surface Unit - Gas
International D8321TA-L Surface Unit - Gas
International D8321TS-L Surface Unit - Gas
Whirlpool D9757W2
Whirlpool D9757W5
Whirlpool D9757W6
Whirlpool D9757^1
Whirlpool D9757^2
Whirlpool D9757^5
Whirlpool D9757^6
Amana DA1040 Washer - Top Loading
Amana DA3000 Washer - Top Loading
Amana DA3001 Washer - Top Loading
Amana DA3080 Washer - Top Loading
Amana DA3100 Washer - Top Loading
Amana DA3101 Washer - Top Loading
Amana DA3201 Washer - Top Loading
Amana DA3210 Washer - Top Loading
Amana DA3211 Washer - Top Loading
Amana DA3500 Washer - Top Loading
Amana DA3501 Washer - Top Loading
Amana DA3660 Washer - Top Loading
  #2 (permalink)
Old 07-20-2009, 01:50 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The "F0" error code means:"Function key stuck". The correction recommended by the manufacturer is to replace the touch pad first and, if it would not help, then replace the control board (aka timer).
The touch pad has been discontinued by the manufacturer. Looks like it's a time for a new range.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 07-20-2009, 01:56 PM
Junior Member
Default
Darn it! And it's only lasted 27 years!
I did read somewhere that if I disconnect the touch pad and reconnect the timer and the timer doesn't work, that it might only be the timer that's bad. True?
  #4 (permalink)
Old 07-20-2009, 02:50 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You can try your luck. Hope dies last.
__________________
  #5 (permalink)
Old 07-20-2009, 03:12 PM
Junior Member
Default
Thanks! I'll give it a shot.
  #6 (permalink)
Old 07-20-2009, 08:52 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
__________________
  #7 (permalink)
Old 07-22-2009, 08:50 AM
Junior Member
Default frustrating
Well, I re-connected the timer without the keypad and it powered up. I re-set the clock, plugged the keypad back into the timer and 'presto' it worked. The oven came on using the keypad and I walked away for several minutes. Upon return, the 'F0' code had reappeared and the oven shut down. Do you still think that the keypad is toast?
  #8 (permalink)
Old 07-22-2009, 01:06 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Most likely the problem is a bad touch pad. There is very small chance for the control board to be bad in such situation.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Jenn Air Over with F5 error code jimwhitingtx Oven Repair (including Ranges and Cooktops) 0 01-16-2010 08:37 AM
F14 code Jenn-air shokwaves Oven Repair (including Ranges and Cooktops) 1 10-06-2009 04:06 PM
Jenn Air F-5 code lastcast33 Oven Repair (including Ranges and Cooktops) 5 06-30-2009 08:04 PM
Jenn Air Oven no longer works(No code) donna o Oven Repair (including Ranges and Cooktops) 3 11-28-2008 04:54 PM
Jenn Air F1 Error Code noyneksiwel Oven Repair (including Ranges and Cooktops) 3 11-24-2008 08:45 PM
