Stuck at 350 or lower
Sometimes the oven timer doesn't function right and the oven temp control can only be decreased, not increased. For example when you start at 350 and hit the UP arrow, the temp setting will decrease to 345, 340, 335 etc etc. It won't go above 350. Othertimes it works fine. Is it the control board or the high temp sensor? |
| All times are GMT -7. The time now is 03:05 PM. |
