Discuss
Oven (and other appliances) won't heat - caused by electricity fluctuation?
 in
Today our electrical supply went funny - some lights became much dimmer than usual, the time on the radio became
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven (and other appliances) won't heat - caused by electricity fluctuation?
  #1 (permalink)
Old 02-05-2012, 02:45 PM
Junior Member
AaronD is on a distinguished road
Default Oven (and other appliances) won't heat - caused by electricity fluctuation?
Brand: -brand-   Age: 1 - 5 years
Today our electrical supply went funny - some lights became much dimmer than usual, the time on the radio became very dim, and internet went down for 20 min - but nothing lost power. Ten minutes later it was normal again. Afterwards, the oven will not heat (all surface elements, and inside coils, won't heat) but the oven itself has power (display and oven light are fine). We were using a surface element before this power fluctuation and it was working fine then just stopped.
Also, our dryer (laundry) has power but will not heat, and our electric baseboard heaters appear to have stopped working (perfect - it's winter and we're in Montreal)
Any ideas? Thanks!
Ads By Google
  #2 (permalink)
Old 02-07-2012, 06:03 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Sounds like you may have lost half the line.
Try shutting the main breaker off then back on.
If this does nothing then you will have to check the power at either the stove or dryer receptacle.
L1 and L2 to Neutral should both be 120 volts.
L1 to L2 should be 240 volts.
If you have no electrical experience it may be advisable to call an electrician.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Used / Reconditioned Appliances gilkelley Oven Repair (including Ranges and Cooktops) 0 01-30-2011 06:53 PM
No electricity to magic chef double oven electric range Phee Oven Repair (including Ranges and Cooktops) 0 01-24-2011 02:42 PM
Freezer Temperature fluctuation harveystark Refrigerator & Freezer Repair 3 01-12-2011 02:51 AM
Can I operate oven without electricity? TimReitz Oven Repair (including Ranges and Cooktops) 0 07-26-2010 05:47 PM
Upright Freezer Temp fluctuation jellis86 Refrigerator & Freezer Repair 0 08-01-2008 09:01 AM
