Hi! I thought I had this problem figured out after searching through the various posts on this site. I have a Harwick electric range/oven (model ED1-56-A-19). I think it was manufactured in 1987. Everything works fine except for the 8" burner, which gets HOT almost instantly when switched onto "Lo". I tried replacing the burner element and the Receptable terminal block (Whirlpool model AP3075808) and it still did not correct the problem. The oven and other 3 burners work fine. Can someone please advise?
Thanks!
