Discuss
Stove top
 in
How do I lift up the stove to work on one of the burners? Ads By Google Related Models Whirlpool
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Stove top
  #1 (permalink)
Old 07-18-2009, 11:23 PM
Junior Member
Avionics Joe is on a distinguished road
Cool Stove top
Model Number: FGF334BGWH   Brand: Frigidaire   Age: 5 - 10 years
Ads By Google
Related Models
Whirlpool FGP335EQ0
Whirlpool FGP335EW0
Whirlpool FGP335GN0
Whirlpool FGP335GN1
Whirlpool FGP335GQ0
Whirlpool FGP335GQ1
Whirlpool FGP335GW0
Whirlpool FGP335GW1
Whirlpool FGP335HN0
Whirlpool FGP335HQ0
Whirlpool FGP335HW0
Whirlpool FGP335VL0
Whirlpool FGP335VL1
Whirlpool FGP335VL2
Whirlpool FGP335VL3
Whirlpool FGP335VW0
Whirlpool FGP335VW1
Whirlpool FGP335VW2
Whirlpool FGP335VW3
Whirlpool FGP335YL0
Whirlpool FGP335YL1
Whirlpool FGP335YL2
Whirlpool FGP335YW0
Whirlpool FGP335YW1
Whirlpool FGP335YW2
Whirlpool FGP337GN0
Whirlpool FGP337GN1
Whirlpool FGP337GN5
Whirlpool FGP337GQ0
Whirlpool FGP337GQ1
Whirlpool FGP337GQ5
Whirlpool FGP337GW0
Whirlpool FGP337GW1
Whirlpool FGP337GW5
Whirlpool FGP337HN0
Whirlpool FGP337HQ0
Whirlpool FGP337HW0
Whirlpool FGP337KN0
Whirlpool FGP337KQ0
Whirlpool FGP337KW0
Whirlpool FGP337KW1 30" Gas Freestanding Standard Clean Range Electro
Whirlpool FGP345VL0
Whirlpool FGP345VL1
Whirlpool FGP345VL2
Whirlpool FGP345VW0
Whirlpool FGP345VW1
Whirlpool FGP345VW2
Whirlpool FGP345YL0
Whirlpool FGP345YW0
Whirlpool FGP355VL0
Whirlpool FGP355VL1
Whirlpool FGP355VL2
Whirlpool FGP355VL3
Whirlpool FGP355VW0
Whirlpool FGP355VW1
Whirlpool FGP355VW2
Whirlpool FGP355VW3
Whirlpool FGP355YL0
Whirlpool FGP355YW0
Whirlpool FGP357XL0
Whirlpool FGP357XW0
Whirlpool FGP357YL0
Whirlpool FGP357YL1
Whirlpool FGP357YL3
Whirlpool FGP357YW0
Whirlpool FGP357YW1
Whirlpool FGP357YW2
Whirlpool FGP357YW3
Frigidaire FGQ1442ES0 Frigidaire/dryer
Frigidaire FGQ332ES0 Frigidaire/gas Dryer
Frigidaire FGQB2152FE0 Frigidaire/dryer
Frigidaire FGQB4000FS0 Frigidaire/dryer
Frigidaire FGQBB30DS0 Frigidaire/dryer
Frigidaire FGR211AS0 Dryer - Frigidaire
Frigidaire FGR211AS1 Dryer - Frigidaire
Frigidaire FGR211AS2 Frigidaire/gas Dryer
Frigidaire FGR211AS3 Frigidaire/gas Dryer
Frigidaire FGR211AS4 Frigidaire/dryer
Frigidaire FGR211MAS0 Frigidaire/dryer
Frigidaire FGR221AS0 Dryer - Frigidaire
Frigidaire FGR231AS0 Dryer - Frigidaire
Frigidaire FGR231AS1 Dryer - Frigidaire
Frigidaire FGR231AS2 Frigidaire/dryer
Frigidaire FGR231AS3 Frigidaire/gas Dryer
Frigidaire FGR231AS4 Frigidaire/dryer
Frigidaire FGR231CAS4 Frigidaire/dryer
Frigidaire FGR311FS0 Frigidaire/dryer
Frigidaire FGR331AS0 Dryer - Frigidaire
Frigidaire FGR331AS1 Dryer - Frigidaire
Frigidaire FGR331KAS1 Frigidaire/gas Dryer
Frigidaire FGR341AC0 Frigidaire/dryer
Frigidaire FGR341AC1 Frigidaire/dryer
Frigidaire FGR341AS0 Dryer - Frigidaire
Frigidaire FGR341AS1 Dryer - Frigidaire
Frigidaire FGR641FS0 Frigidaire/dryer
Frigidaire FGR6600ES0 Frigidaire/dryer
Frigidaire FGR6600FS0 Frigidaire/dryer
Frigidaire FGRB5700DS0 Frigidaire/dryer
Frigidaire FGRB6600ES0 Frigidaire/dryer
Frigidaire FGRB6600FS0 Frigidaire/dryer
Frigidaire FGRB7800DS0 Frigidaire/dryer
Whirlpool FGS325RQ0 30" Gas Freestanding Self Clean Range
Whirlpool FGS325RQ1 30" Gas Freestanding Self Clean Range
Whirlpool FGS325RQ2 30" Gas Freestanding Self Clean Range
Whirlpool FGS326RD0 30" Gas Freestanding Self Clean Range
Whirlpool FGS326RD1 30" Gas Freestanding Self Clean Range
Whirlpool FGS326RD2 30" Gas Freestanding Self Clean Range
Whirlpool FGS326RD3 30" Gas Freestanding Self Clean Range
Whirlpool FGS335EN0
Whirlpool FGS335EQ0
Whirlpool FGS335EW0
Whirlpool FGS337GN0
Whirlpool FGS337GN1
Whirlpool FGS337GN5
Whirlpool FGS337GQ0
Whirlpool FGS337GQ1
Whirlpool FGS337GQ5
Whirlpool FGS337GQ6
Whirlpool FGS337GQ7
Whirlpool FGS337GW0
  #2 (permalink)
Old 07-19-2009, 01:21 PM
Senior Expert
APP Volunteer
Dan O. is on a distinguished road
Question Absolutely necessary?
What kind of "work"? Most service to them is done from the top unless access to its gas supply is needed.
Quote:
How do I lift up the stove [top]
Your model has 'sealed' burners. The burner bases are secured to the top with screws around their perimeter. All of those burner bases would have to have their screws removed first and there might be additional screws for the top under the front lip of the cooktop.
Do NOT attempt to raise the top without first disconnecting each of the burners bases from it. Damage to the gas supply tubing can result otherwise.
The burner base screws frequently become 'seized' in place with age making them difficult (and sometimes impossible) to remove. If the screw heads get stripped or the screws break in the process of removal, the burner base(s) would then usually have to be replaced... along with each of the damaged screws. It is best to try to avoid tampering with their mounting unless it is absolutely necessary.
JMO
Dan O.
www.Appliance411.com
The Appliance Information Site
=D~~~~~~
  #3 (permalink)
Old 07-19-2009, 02:41 PM
Junior Member
Default
Thank you, the Burner Ignitor 316011200is cracked and I was going to replace it. But now I don't think it is worth it.
  #4 (permalink)
Old 03-07-2011, 03:14 PM
Junior Member
timothyso is on a distinguished road
Default Silly screws.
This is a REAL problem with low profile screws. My model Frigidaire was only 7 years old but the ignitor died.
The first screw head just snapped of. No pressure at all.
The second one I think was only attached via baked on carbon.
The third (all on one burner) would not budge. But didn't want to
break it so I soaked it with everything possible 3 times. WD40
Over Cleaner and an oil based cleaner.
STill nada and then really torqued it and snapped off as well.
One burner 3 broken screws. 3 burners and 9 screws to go.
End reason 100% broken screws. Well. Since that mean an 11$ easy out
MIGHT work on the ultra small screws. I decide to clamp each burner on a jig and ran a very nice high speed metal drill into each. Then by hand carefully retapped each screw to the size I wanted (can't remember now but still real small) then had to grind down the heads so that the cover tray didn't hit them.
Total time 4 hours labor. (after figuring out what to do)
12 screws at .11cents each at ace. (had the tap)
3.89 for a new metal drill bit.
Had the grinder.
12.89 for the ignitor. All done happy. Pissed at ultra stupid design by
these people.
OTHER CHOICE was buy new sealed burner that come with screws at 30.54 EACH.
BTW even IF the screws come out with an easy-out and don't need retapping everybody want .08 up to 2.38 per screw and shipping at about 8-12$ for the order or inother words 8.50-$41.51for 12 screws!
Sears was the worst at 8 for shipping 2.38 a screw and for 12 screws the shipping went up to 12.95 which was 41.51 for 12 screws mailed to me!
READ other people work.
RESEARCH
and then DIYS
  #5 (permalink)
Old 08-21-2011, 08:15 AM
Junior Member
palasko is on a distinguished road
Default LIft top on frigidaire range
Quote:
ON the front corners, you can push in a clip by using a butter knife or some such thing, one at a time, and lift the top a little. That will give you the space to wiggle the ignitor connection wires, which may be all it takes. When you lift the top, the burners are still connected with aluminum gas tubes so don't break them. If you need to take it all the way up, Remove the burner mounting screws with a quarter inch hex
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Stove top Glenn Mathews Oven Repair (including Ranges and Cooktops) 0 12-29-2009 06:17 PM
stove dmck1nney@netzero.com Oven Repair (including Ranges and Cooktops) 2 09-30-2009 11:50 PM
gas stove kenrays Oven Repair (including Ranges and Cooktops) 5 09-09-2009 04:00 PM
stove whitealligator Oven Repair (including Ranges and Cooktops) 3 12-04-2008 10:00 PM
stove Robin1 Oven Repair (including Ranges and Cooktops) 1 10-17-2007 01:06 PM
