my whirlpool glass top stove,the cook top light stays on and not going off! please help me.
It would be helpful if you could post the model number for us, thanks.
Hello Moveta, did you get the problem fixed? I had the same problem with my Whirlpool range Model # WFE361LVB. It turned out to be the Infinite Switch for the large surface: part number AP3095444. My stove uses two different Infinite Switches; one for the LARGE burner and another for the SMALL burner (AP3095448). Since I do not know if you have the same cooktop stove as I do, please send Gene the model number for your stove and he will assist you. With his help I was able to fix my stove and it is working properly again.
