Discuss
Frigidaire oven takes 5 minutes to light
 in
When I turn the oven on to any temperature, it takes a minimum of 5 minutes for the gas to
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Frigidaire oven takes 5 minutes to light
  #1 (permalink)
Old 07-18-2009, 11:40 AM
Junior Member
riopel is on a distinguished road
Default Frigidaire oven takes 5 minutes to light
Model Number: FGF337ABA   Brand: Frigidaire   Age: 5 - 10 years
When I turn the oven on to any temperature, it takes a minimum of 5 minutes for the gas to light. Sometimes it takes a lot longer. When the bake button is pushed, the glow plug starts glowing immediately. Then I wait.
What do I need to replace?
Related Models
Frigidaire FGF337ABA Frigidaire/gas Range
Frigidaire FGF337ABB Frigidaire/gas Range
Frigidaire FGF337ABC Frigidaire/gas Range
Frigidaire FGF337ABD Frigidaire/gas Range
Frigidaire FGF337ABE Frigidaire/gas Range
Frigidaire FGF337ABF Frigidaire/gas Range
Frigidaire FGF337ABH Frigidaire/gas Range
Frigidaire FGF337ABJ Frigidaire/gas Range
Frigidaire FGF337ABL Frigidaire/range
Frigidaire FGF337ASA Frigidaire/gas Range
Frigidaire FGF337ASB Frigidaire/gas Range
Frigidaire FGF337ASC Frigidaire/gas Range
Frigidaire FGF337ASD Frigidaire/gas Range
Frigidaire FGF337ASE Frigidaire/gas Range
Frigidaire FGF337ASF Frigidaire/gas Range
Frigidaire FGF337ASH Frigidaire/gas Range
Frigidaire FGF337ASJ Frigidaire/gas Range
Frigidaire FGF337ASL Frigidaire/range
Frigidaire FGF337AUA Frigidaire/gas Range
Frigidaire FGF337AUC Frigidaire/gas Range
Frigidaire FGF337AUD Frigidaire/gas Range
Frigidaire FGF337AUE Frigidaire/gas Range
Frigidaire FGF337AUF Frigidaire/gas Range
Frigidaire FGF337AUH Frigidaire/gas Range
Frigidaire FGF337AUJ Frigidaire/gas Range
Frigidaire FGF337AUL Frigidaire/range
Frigidaire FGF337AWA Frigidaire/gas Range
Frigidaire FGF337AWC Frigidaire/gas Range
Frigidaire FGF337AWD Frigidaire/gas Range
Frigidaire FGF337AWE Frigidaire/gas Range
Frigidaire FGF337AWF Frigidaire/gas Range
Frigidaire FGF337AWH Frigidaire/gas Range
Frigidaire FGF337AWJ Frigidaire/gas Range
Frigidaire FGF337AWL Frigidaire/range
Frigidaire FGF337BCA Frigidaire/gas Range
Frigidaire FGF337BCB Frigidaire/gas Range
Frigidaire FGF337BCC Frigidaire/gas Range
Frigidaire FGF337BCD Frigidaire/gas Range
Frigidaire FGF337BCE Frigidaire/gas Range
Frigidaire FGF337BCF Frigidaire/gas Range
Frigidaire FGF337BCG Frigidaire/range
Frigidaire FGF337BCH Frigidaire/range
Frigidaire FGF337BCL Frigidaire/range
Frigidaire FGF337EBA Frigidaire/gas Range
Frigidaire FGF337EBC Frigidaire/gas Range
Frigidaire FGF337EBD Frigidaire/range
Frigidaire FGF337ECA Frigidaire/gas Range
Frigidaire FGF337ECC Frigidaire/gas Range
Frigidaire FGF337ECD Frigidaire/range
Frigidaire FGF337ESA Frigidaire/gas Range
Frigidaire FGF337ESC Frigidaire/gas Range
Frigidaire FGF337ESD Frigidaire/range
Frigidaire FGF337EUA Frigidaire/gas Range
Frigidaire FGF337EUC Frigidaire/gas Range
Frigidaire FGF337EUD Frigidaire/range
Frigidaire FGF337EWA Frigidaire/gas Range
Frigidaire FGF337EWC Frigidaire/gas Range
Frigidaire FGF337EWD Frigidaire/range
Frigidaire FGF337GBA Frigidaire/range
Frigidaire FGF337GBB GAS RANGE
Frigidaire FGF337GBC GAS RANGE
Frigidaire FGF337GBD GAS RANGE
Frigidaire FGF337GBE GAS RANGE
Frigidaire FGF337GBF GAS RANGE
Frigidaire FGF337GBG GAS RANGE
Frigidaire FGF337GCA Frigidaire/range
Frigidaire FGF337GCB GAS RANGE
Frigidaire FGF337GCC GAS RANGE
Frigidaire FGF337GCD GAS RANGE
Frigidaire FGF337GCE GAS RANGE
Frigidaire FGF337GCF GAS RANGE
Frigidaire FGF337GCG GAS RANGE
Frigidaire FGF337GCH GAS RANGE
Frigidaire FGF337GCJ GAS RANGE
Frigidaire FGF337GCK GAS RANGE
Frigidaire FGF337GSA Frigidaire/range
Frigidaire FGF337GSB GAS RANGE
Frigidaire FGF337GSC GAS RANGE
Frigidaire FGF337GSD GAS RANGE
Frigidaire FGF337GSE GAS RANGE
Frigidaire FGF337GSF GAS RANGE
Frigidaire FGF337GSG GAS RANGE
Frigidaire FGF337GUA Frigidaire/range
Frigidaire FGF337GUB GAS RANGE
Frigidaire FGF337GUC GAS RANGE
Frigidaire FGF337GUD GAS RANGE
Frigidaire FGF337GUE GAS RANGE
Frigidaire FGF337GUF GAS RANGE
Frigidaire FGF337GWA Frigidaire/range
Frigidaire FGF337GWB GAS RANGE
Frigidaire FGF337GWC GAS RANGE
Frigidaire FGF337GWD GAS RANGE
Frigidaire FGF337GWE GAS RANGE
Frigidaire FGF337GWF GAS RANGE
Frigidaire FGF343BADA Frg(v2) / Gas Range
Frigidaire FGF343BADB Frg(v3) / Gas Range
Frigidaire FGF343BAWA Frg(v1) / Gas Range
Frigidaire FGF343BAWB Frg(v4) / Gas Range
Frigidaire FGF345BHWA Frg(v4) / Gas Range
Frigidaire FGF345BHWB Frigidaire/gas Range
Frigidaire FGF345BHWC Frigidaire/gas Range
Frigidaire FGF345GSA GAS RANGE
Frigidaire FGF345GSB GAS RANGE
Frigidaire FGF345GSC GAS RANGE
Frigidaire FGF345GSD GAS RANGE
Frigidaire FGF348KBA GAS RANGE
Frigidaire FGF348KBB GAS RANGE
Frigidaire FGF348KCA GAS RANGE
Frigidaire FGF348KCB GAS RANGE
Frigidaire FGF348KCC GAS RANGE
Frigidaire FGF348KCD GAS RANGE
Frigidaire FGF348KCE GAS RANGE
Frigidaire FGF348KCF GAS RANGE
Frigidaire FGF348KCG GAS RANGE
Frigidaire FGF348KCH GAS RANGE
Frigidaire FGF348KCJ GAS RANGE
Frigidaire FGF348KCK GAS RANGE
Frigidaire FGF348KMA GAS RANGE
Frigidaire FGF348KMB GAS RANGE
Frigidaire FGF348KSA GAS RANGE
  #2 (permalink)
Old 07-18-2009, 11:10 PM
Junior Member
Avionics Joe is on a distinguished road
Default
First make sure no gas is flowing by trying to light with a match.
If that does not work the valve is bad, follow the wires from the glow plug the the valve at the base of the burner.
  #3 (permalink)
Old 07-19-2009, 12:59 PM
Senior Expert
APP Volunteer
Dan O. is on a distinguished road
Arrow Clarification needed
Is gas flowing to the oven burner before that? Can you smell unignited gas while waiting for ignition??
Quote:
the glow plug starts glowing immediately. Then I wait. What do I need to replace?
If gas is NOT flowing to the oven burner once the ignitor is glowing as hot as it can, there could be a problem in the oven gas valve but more likely the ignitor. And yes, an ignitor can glow and still be defective.
The only way to determine which is responsible with any certainty is by testing the amperage draw on the ignitor circuit as described at the following link.
LINK > Understanding Gas Oven Ignition Systems
If gas IS being released into the oven burner and it is just not igniting (which would usually produce a noticeable odor), the ignitor not glowing hot enough or possibly the gas ports nearest the ignitor may be obstructed.
LINK > Frigidaire FGF337ABA Oven Ignitor
JFYI
Dan O.
www.Appliance411.com
The Appliance Information Site
=D~~~~~~
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven burner wont light or takes a long time to light shadyray Oven Repair (including Ranges and Cooktops) 5 03-21-2016 08:44 PM
Frigidaire oven takes 45 minutes to preheat nanmar535 Oven Repair (including Ranges and Cooktops) 8 09-15-2009 06:24 PM
GE Oven Igniter lights but oven takes forever to light up Byl Oven Repair (including Ranges and Cooktops) 3 08-18-2009 10:47 AM
gas oven takes too long to light mackdj10@gmail.com Oven Repair (including Ranges and Cooktops) 1 05-31-2009 03:20 PM
Frigidaire gas stove oven takes too long to light tski2 Oven Repair (including Ranges and Cooktops) 1 12-12-2008 12:37 PM
