Large dual burner on right front--outer burner quit working. Called service dept of appliance dlr. They looked and said they needed to order a burner. 2wks later new burner would not work. Checked out control and said ok. Service man said they can no longer get the correct replacement burner for this range. He put old burner back and now the inner burner works when the swith is set for the out burner. Outer burner still does not work. Since I came across this web-site and seeing that there is a so called replacement bruner (dual element Part # PS1655200) which I assume to be correct. I was thinking about ordering and trying it. I was kind of suprised at the logic I was given especially from the appliance store service dept. Other than that the stove looks like new and works well. Your thoughts and ideas?
