Hi, I have gas magic chef 8261rw. Its spark ignition is intermittent. Sometimes it starts sparking by itself. Sometimes it doesn't spark at all, then it starts working again a few days later. Right now it is not sparking at all. Looks like I'll have to first try cleaning spark module (AP4010034) contacts. If that doesn't work, I may have to replace spark module (AP4010034). In any case, I'll have to remove Glass Main Top (AP204553) to access it. Since Glass Main Top is a discontinued item, there are no instructions on how to remove it. Could any one help please? If this Glass Main Top (AP204553) gets damaged, how does one go about finding its replacement? If not, do I need to replace the whole cooktop? Thanks
