Discuss
Ignitor won't shut off on Thermador range
 in
The ignitor arcs continously with the burner shut off. This is a gas cooktop and the burner is not the
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Ignitor won't shut off on Thermador range
  #1 (permalink)
Old 01-31-2012, 12:41 PM
Junior Member
David Bockstege is on a distinguished road
Default Ignitor won't shut off on Thermador range
Model Number: 305s   Brand: Thermador   Age: 1 - 5 years
The ignitor arcs continously with the burner shut off. This is a gas cooktop and the burner is not the solenoid controlled unit with the extra low simmer setting. It gets power directly from the rheostat. Is the switch shorted, so that it is putting power on the ignitor with it in off?
Ads By Google
Related Models
Amana 3072.000 Mwave - Family Size (60 Hz)
Amana 3074.000 Mwave - Family Size (60 Hz)
Amana 3074.A00 Mwave - Family Size (60 Hz)
Amana 3090.000 Mwave - Family Size (60 Hz)
Amana 3094.000 Mwave - Family Size (60 Hz)
Amana 3094.A00 Mwave - Family Size (60 Hz)
Frigidaire 30CGMCWBN1 Tap(v1) / Gas Range
Frigidaire 30CGMCWBN2 Tap(v2) / Gas Range
Frigidaire 30CPMCWBN1 Tap(v1) / Gas Range
Frigidaire 30CPMCWBN2 Tap(v2) / Gas Range
Frigidaire 30CPMCWBN3 Tap(v3) / Gas Range
Frigidaire 30DEMBWDD1 Tap(v1) / Electric Range
Frigidaire 30DEMBWDD1-23 Tap(v2) / Electric Range
Frigidaire 30DEMDWED0 Tap(v1) / Electric Range
Frigidaire 30DEMDWED0-23 Tap(v2) / Electric Range
Frigidaire 30DGMBWDN0 Tap(v1) / Gas Range
Frigidaire 30DGMCWAN4 Tap(v1) / Gas Range
Frigidaire 30DPCDWGN-23-01 Tap(v2) / Gas Range
Frigidaire 30DPCDWGN1 Tap(v1) / Gas Range
Frigidaire 30DPMBWAN6 Tap(v1) / Gas Range
Frigidaire 30DPMBWAP4 Tap(v1) / Gas Range
Frigidaire 30DPMBWAP5 Tap(v2) / Gas Range
Frigidaire 30DPMBWAP6 Tap(v3) / Gas Range
Frigidaire 30DPMCWAN5 Tap(v1) / Gas Range
Frigidaire 30DPMDWEN1 Tap(v1) / Gas Range
Frigidaire 30DPMDWEN1-23 Tap(v2) / Gas Range
Frigidaire 30DPMDWEN2 Tap(v3) / Gas Range
Frigidaire 30DPMDWEN2-23 Tap(v4) / Gas Range
Frigidaire 30DPMDWGN01-23 Tap(v2) / Gas Range
Frigidaire 30DPMDWGN1 Tap(v1) / Gas Range
Frigidaire 30IGCDWAN5 Tap(v1) / Gas Range
Frigidaire 30IPCDWAN5 Tap(v1) / Gas Range
Frigidaire 30IPCDWAN6 Tap(v2) / Gas Range
Frigidaire 30IPCDWAN7 Tap(v1) / Gas Range
Frigidaire 30KEMAWAD3 Tap(v1) / Electric Range
Frigidaire 30KEMAWAD5 Tap(v1) / Electric Range
Frigidaire 30KGMAWAN3 Tap(v1) / Gas Range
Frigidaire 30KGMAWAN3-23 Tap(v2) / Gas Range
Frigidaire 30KGMAWAN4 Tap(v3) / Gas Range
Frigidaire 30KGMAWAN4-23 Tap(v4) / Gas Range
Frigidaire 30KPMAWAN3 Tap(v1) / Gas Range
Frigidaire 30KPMAWAN4 Tap(v2) / Gas Range
Frigidaire 30KPMAWAN5 Tap(v3) / Gas Range
Frigidaire 30KPMAWHN1 Tap(v1) / Gas Range
Frigidaire 30KPMAWHN2 Tap(v1) / Gas Range
Frigidaire 30PPSKWDN0 Tap(v1) / Gas Range
Frigidaire 30PPSKWDN0-23 Tap(v2) / Gas Range
Frigidaire 30PPSKWDN0-32 Tap(v3) / Gas Range
Amana 30R Freezer - Vertical
Amana 30RS Freezer - Vertical
Frigidaire 30TESKWED-04-23 Tap(v2) / Electric Range
Frigidaire 30TESKWED-23 Tap(v2) / Electric Range
Frigidaire 30TESKWED-23-02 Tap(v2) / Electric Range
Frigidaire 30TESKWED-23-03 Tap(v4) / Electric Range
Frigidaire 30TESKWED1 Tap(v1) / Electric Range
Frigidaire 30TESKWED2 Tap(v1) / Electric Range
Frigidaire 30TESKWED3 Tap(v3) / Electric Range
Frigidaire 30TESKWED4 Tap(v1) / Electric Range
Hoover 31
Frigidaire 31-1049-00-01 Tap(v1) / Electric Range
Frigidaire 31-1049-00-02 Tap(v3) / Electric Range
Frigidaire 31-1049-00-03 Tap(v1) / Electric Range
Frigidaire 31-1049-00-04 Tap(v1) / Electric Range
Frigidaire 31-1049-00-05 Tap(v1) / Electric Range
Frigidaire 31-1049-00-06 Tap(v1) / Electric Range
Frigidaire 31-1049-23-01 Tap(v2) / Electric Range
Frigidaire 31-1049-23-02 Tap(v4) / Electric Range
Frigidaire 31-1049-23-03 Tap(v2) / Electric Range
Frigidaire 31-1049-23-04 Tap(v2) / Electric Range
Frigidaire 31-1049-23-05 Tap(v2) / Electric Range
Frigidaire 31-1049-23-06 Tap(v2) / Electric Range
Frigidaire 31-2207-00-01 Tap(v1) / Electric Range
Frigidaire 31-2207-00-02 Tap(v4) / Electric Range
Frigidaire 31-2207-00-03 Tap(v7) / Electric Range
Frigidaire 31-2207-23-01 Tap(v2) / Electric Range
Frigidaire 31-2207-23-02 Tap(v5) / Electric Range
Frigidaire 31-2207-23-03 Tap(v8) / Electric Range
Frigidaire 31-2207-66-01 Tap(v3) / Electric Range
Frigidaire 31-2207-66-02 Tap(v6) / Electric Range
Frigidaire 31-2207-66-03 Tap(v9) / Electric Range
Frigidaire 31-2208-00-01 Tap(v1) / Electric Range
Frigidaire 31-2208-00-02 Tap(v4) / Electric Range
Frigidaire 31-2208-00-03 Tap(v7) / Electric Range
Frigidaire 31-2208-23-01 Tap(v2) / Electric Range
Frigidaire 31-2208-23-02 Tap(v5) / Electric Range
Frigidaire 31-2208-23-03 Tap(v8) / Electric Range
Frigidaire 31-2208-66-01 Tap(v3) / Electric Range
Frigidaire 31-2208-66-02 Tap(v6) / Electric Range
Frigidaire 31-2208-66-03 Tap(v9) / Electric Range
Frigidaire 31-2232-00-01 Tap(v1) / Electric Range
Frigidaire 31-2232-00-02 Tap(v1) / Electric Range
Frigidaire 31-2232-00-03 Tap(v1) / Electric Range
Frigidaire 31-2232-23-01 Tap(v2) / Electric Range
Frigidaire 31-2232-23-02 Tap(v2) / Electric Range
Frigidaire 31-2232-23-03 Tap(v2) / Electric Range
Frigidaire 31-2237-00-01 Tap(v1) / Electric Range
Frigidaire 31-2237-00-02 Tap(v4) / Electric Range
Frigidaire 31-2237-00-03 Tap(v1) / Electric Range
Frigidaire 31-2237-23-01 Tap(v2) / Electric Range
Frigidaire 31-2237-23-02 Tap(v5) / Electric Range
Frigidaire 31-2237-23-03 Tap(v2) / Electric Range
Frigidaire 31-2237-66-01 Tap(v3) / Electric Range
Frigidaire 31-2237-66-02 Tap(v6) / Electric Range
Frigidaire 31-2237-66-03 Tap(v3) / Electric Range
Frigidaire 31-2238-00-05 Tap(v1) / Electric Range
Frigidaire 31-2238-00-06 Tap(v4) / Electric Range
Frigidaire 31-2238-23-05 Tap(v2) / Electric Range
Frigidaire 31-2238-23-06 Tap(v5) / Electric Range
Frigidaire 31-2238-66-05 Tap(v3) / Electric Range
Frigidaire 31-2238-66-06 Tap(v6) / Electric Range
Frigidaire 31-2239-00-01 Tap(v1) / Electric Range
Frigidaire 31-2239-00-02 Tap(v1) / Electric Range
Frigidaire 31-2239-00-03 Tap(v3) / Electric Range
Frigidaire 31-2239-00-04 Tap(v1) / Electric Range
Frigidaire 31-2239-00-05 Tap(v1) / Electric Range
Frigidaire 31-2239-00-06 Tap(v1) / Electric Range
Frigidaire 31-2239-23-01 Tap(v2) / Electric Range
Frigidaire 31-2239-23-02 Tap(v2) / Electric Range
Frigidaire 31-2239-23-03 Tap(v4) / Electric Range
Frigidaire 31-2239-23-04 Tap(v2) / Electric Range
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thermador RDDS30V - Ignitor replacement? Albert V Oven Repair (including Ranges and Cooktops) 0 03-08-2011 06:55 PM
Thermador cooktop not sparking on any ignitor mlight Oven Repair (including Ranges and Cooktops) 0 04-06-2010 02:08 PM
Thermador cooktop ignitor does not work Homemaker909 Oven Repair (including Ranges and Cooktops) 0 11-15-2009 09:12 PM
Oven Ignitor does not shut off ctjaros Oven Repair (including Ranges and Cooktops) 1 07-10-2009 08:14 AM
ignitor problem on Thermador cook top daneh Oven Repair (including Ranges and Cooktops) 3 10-09-2008 09:22 PM
