Hi, I searched and searched but could not find this. My front right 6" burner gets red hot sometimes, and sometimes it doesn't. I switched the two 6" elements and nothing changes. Could it be the recepticle or terminal block or whatever the correct name is? I think it is pretty old - 1997 I think. Also, if the burner needs replacing, I notice some have 5 turns, while some have 4. Are the 5 turn coils hotter? thanks for any h elp you can give
The 5 coil burners heat up faster. Could be a problem with the burner switch too.
