When using the tempeture probe it appears to work fine but after a few minutes will get an error message to insert probe after it is already in. Will re do the steps and will seem to be working fine but then after a several minutes will get the same error message. Have replaced the probe but still getting the same message. It will take longer to receive the message with the new probe, for some reason after the oven heats up it does not recognize the probe. Any help would be greatly appriciated.
