Discuss
oven control panel no power
 in
Hello, I have whirlpool double oven which went dead couple of months ago. It started out as display lights fading
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » oven control panel no power
  #1 (permalink)
Old 01-28-2012, 06:21 PM
Junior Member
ugone is on a distinguished road
Default oven control panel no power
Model Number: rbd305pdb14   Brand: Whirlpool   Age: 1 - 5 years
Hello,
It started out as display lights fading over a week period and than went black without any error code.
when open door lights inside turn on.
push any buttons and i hear push button sounds but when i push start button, it beeps few times but nothing happens.
1) I checked for POWER INTO THE CONTROL BOARD by measuring voltage at pin 1 and 3 on connector p24 and got 120 volts across pin 1 and 3.So thermal fuse alright.
2) POWER TO THE TRANSFORMER:At connector 16 i measured voltage across pin 5 and 7 and it was 120v across those two pins so power is going to transformer from board.
Next i measured power comming out of the transformer at pin 2 and 3 on connector p16 and found it to be 24v which means transformer is working and stepping down voltage from 120 to 24 to go into the board.
Does this eliminate as bad board? If it does than
What could be causing this kind of malfunction where there is no display to the control panel?
To do these tests, I followed these instruction.
Whirlpool oven is dead – no display, no beeping. Does the control board need to be repaired? « ApplianceBoards
Ads By Google
Related Models
Whirlpool RBD305PDB14 30" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD305PDB15 30" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD305PDB2
Whirlpool RBD305PDB3
Whirlpool RBD305PDB4
Whirlpool RBD305PDB6
Whirlpool RBD305PDB7
Whirlpool RBD305PDB8
Whirlpool RBD305PDB9
Whirlpool RBD305PDQ1
Whirlpool RBD305PDQ10
Whirlpool RBD305PDQ11
Whirlpool RBD305PDQ12
Whirlpool RBD305PDQ13
Whirlpool RBD305PDQ14 30" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD305PDQ15 30" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD305PDQ2
Whirlpool RBD305PDQ3
Whirlpool RBD305PDQ4
Whirlpool RBD305PDQ6
Whirlpool RBD305PDQ7
Whirlpool RBD305PDQ8
Whirlpool RBD305PDQ9
Whirlpool RBD305PDS12
Whirlpool RBD305PDS14 30" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD305PDS15 30" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD305PDT11
Whirlpool RBD305PDT12
Whirlpool RBD305PDT13
Whirlpool RBD305PDT14 30" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD305PDT15 30" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD305PRB00 24" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD305PRQ00 24" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD305PRS00 24" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD305PRT00 24" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD306PDB1
Whirlpool RBD306PDB10
Whirlpool RBD306PDB11
Whirlpool RBD306PDB12
Whirlpool RBD306PDB13
Whirlpool RBD306PDB14 30" Built - in Electric Double Oven Self - Clean Upper and Lower Ovens
Whirlpool RBD306PDB15 30" Built - in Electric Double Oven Self - Clean Upper and Lower Ovens
Whirlpool RBD306PDB2
Whirlpool RBD306PDB4
Whirlpool RBD306PDB6
Whirlpool RBD306PDB7
Whirlpool RBD306PDB8
Whirlpool RBD306PDB9
Whirlpool RBD306PDQ1
Whirlpool RBD306PDQ10
Whirlpool RBD306PDQ11
Whirlpool RBD306PDQ12
Whirlpool RBD306PDQ13
Whirlpool RBD306PDQ14 30" Built - in Electric Double Oven Self - Clean Upper and Lower Ovens
Whirlpool RBD306PDQ15 30" Built - in Electric Double Oven Self - Clean Upper and Lower Ovens
Whirlpool RBD306PDQ2
Whirlpool RBD306PDQ4
Whirlpool RBD306PDQ6
Whirlpool RBD306PDQ7
Whirlpool RBD306PDQ8
Whirlpool RBD306PDQ9
Whirlpool RBD306PDT11
Whirlpool RBD306PDT12
Whirlpool RBD306PDT13
Whirlpool RBD306PDT14 30" Built - in Electric Double Oven Self - Clean Upper and Lower Ovens
Whirlpool RBD306PDT15 30" Built - in Electric Double Oven Self - Clean Upper and Lower Ovens
Whirlpool RBD306PDZ1
Whirlpool RBD306PDZ10
Whirlpool RBD306PDZ2
Whirlpool RBD306PDZ4
Whirlpool RBD306PDZ6
Whirlpool RBD306PDZ7
Whirlpool RBD306PDZ8
Whirlpool RBD306PDZ9
Whirlpool RBD307PDB1
Whirlpool RBD307PDB2
Whirlpool RBD307PDQ1
Whirlpool RBD307PDQ2
Whirlpool RBD307PDQ4
Maytag RBE170PA  Ref - Top Mount
Maytag RBE170PW  Ref - Top Mount
Maytag RBE170TA Ref - Top Mount
Maytag RBE170TM Ref - Top Mount
Maytag RBE170TV Ref - Top Mount
Maytag RBE170TW Ref - Top Mount
Maytag RBE17KA-0A  Ref - Top Mount
Maytag RBE17KN-0A  Ref - Top Mount
Maytag RBE193PA  Ref - Top Mount
Maytag RBE193PW  Ref - Top Mount
Maytag RBE193TA Ref - Top Mount
Maytag RBE193TM Ref - Top Mount
Maytag RBE193TV Ref - Top Mount
Maytag RBE193TW Ref - Top Mount
Maytag RBE19KA-3A  Ref - Top Mount
Maytag RBE19KN-3A  Ref - Top Mount
Maytag RBE19KY-3A  Ref - Top Mount
Maytag RBE214AFM Ref - Top Mount
Maytag RBE214AFV Ref - Top Mount
Maytag RBE214RFA  Ref - Top Mount
Maytag RBE214RFV  Ref - Top Mount
Maytag RBE214TFA Ref - Top Mount
Maytag RBE214TFM Ref - Top Mount
Maytag RBE214TFV Ref - Top Mount
Maytag RBE21KA-4AF  Ref - Top Mount
Maytag RBE21KA4AF  Ref - Top Mount
Maytag RBE21KN-4AF  Ref - Top Mount
Maytag RBE21KN4AF  Ref - Top Mount
Frigidaire RBF136CL Frg(v1) / Electric Cooktop
Frigidaire RBF139CE1 Frg(v1) / Cooktop
Frigidaire RBF139CE2 Frg(v1) / Cooktop
Amana RBG322T Mwave - Cntrtp / Stand Alone
Amana RBG322T1 Mwave - Cntrtp / Stand Alone
Amana RBG358P Mwave - Cntrtp / Stand Alone
Amana RBG622T Mwave - Cntrtp / Stand Alone
Amana RBG635T Mwave - Cntrtp / Stand Alone
Frigidaire RBGF119E1 BLACK Frg(v8) / Electric Cooktops and Control Box
Frigidaire RBGF119EL1 Frg(v7) / Electric Cooktops and Control Box
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
No power to control panel amortellite Washer Repair 1 09-10-2011 06:42 PM
no power to the control panel joebam Dishwasher Repair 0 04-14-2011 11:19 AM
No power to control panel rebelene57 Washer Repair 0 01-26-2011 04:43 PM
No power to control panel jwes Dishwasher Repair 2 05-18-2009 06:18 PM
Power on, no response from control panel for double oven akers5va Oven Repair (including Ranges and Cooktops) 1 09-13-2008 04:47 PM
