Pilot lite is lit When I turn on Bake and set temp. After less then a minute no matter what temp I set temp to the heatup process completes without heating.
I set the Broiler temp to LO and the temp gauge quickly beebs to let me know the temp is ready. but the LO temp does not work. When I set broiler to HI, flames are scene on the heat strip and the HI temp seems to at least work (not sure if temp is accurate)
But no bake temp or Lo broil
