I have a 90’s Magic chef wall oven that when set at say 350F the panel will show it rising in temperature quickly and will then beep at 350. The problem is the ovens actual temp will only be around 175F. If you leave it at that temp setting for some time it will slowly rise but never to the 350 it is set to. I have replaced the Oven Sensor (#12001656) but NO change in the malfunction! Any thoughts on my problem? Thanks, GGC :confused:
