| » Maytag Oven Won't heat up |
Model Number: MER5755QAQ Brand: Maytag Age: 5 - 10 years
My Maytag electric oven won't heat up correctly. I checked the element and it shows 23 ohms so that should be good. The broil element is also good. Voltage to the back of the oven is correct and voltage to the element is also correct. When I turn it on it takes a good hour to get to 200 and then about another 1/2 hour and tops out at 265. Thats as high as it will go.
What do i check next? Ads By Google Related Models |
Mine did this last year and again saturday night, last time ther is a circuit breaker on back lower portion of oven where power cord goes in, round switch held on by two screws, push red button in center, if it clicks you have reset it, if it springs back it is not tripped, fixed my problem.
| Display Modes | |
| maytag super capacity plus oven, can't heat up oven | Muskokangirl | Oven Repair (including Ranges and Cooktops) | 1 | 10-20-2010 08:20 PM |
| Maytag Oven Won't Heat | Miken47 | Oven Repair (including Ranges and Cooktops) | 1 | 06-06-2010 05:09 AM |
| Maytag oven will not heat | 1dlloyd | Oven Repair (including Ranges and Cooktops) | 1 | 06-11-2009 01:41 PM |
| maytag oven won't heat | lbwinters | Oven Repair (including Ranges and Cooktops) | 0 | 05-24-2009 06:19 AM |
| maytag oven won't heat | blonda1972 | Oven Repair (including Ranges and Cooktops) | 3 | 04-16-2009 07:38 PM |
