The oven won't hold set temperature all of the time. This is not only for baking at 350, but when just trying hold food at 180. The wire harness to the igniter has been replaced, the service people even tried a new range control. Nothing has helped, the local service company then decided they didn't know what was wrong, removed the new range control and called it quits. I checked the resistance of the sensor and it checked OK. Also when oven temp isn't holding, I have checked for a repair code, but all that comes up is "good"
