Discuss
GE Stovetop spark module not working
 in
Most common cause for an erratic sparking is a bad ground. You have to check how the cooktop is grounded
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » GE Stovetop spark module not working
  #21 (permalink)
Old 08-08-2008, 12:02 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Most common cause for an erratic sparking is a bad ground. You have to check how the cooktop is grounded and make sure there is a solid ground. If the wires are in the same position it does not mean there is nothing wrong. Also the problem could be a poor house ground too. To make sure this is not the issue connect the body of the cooktop to a water pipe with a good wire.
Ads By Google
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #22 (permalink)
Old 08-08-2008, 12:30 PM
abadfish66's Avatar
Senior Expert
APP Volunteer
abadfish66 is a glorious beacon of light
Default
Also, on some models there is a graphite pad under each burner that must be there, or you can get erratic sparking as well.
__________________
  #23 (permalink)
Old 09-17-2008, 01:18 PM
Junior Member
smithalex is on a distinguished road
Default
I have GE sealed gas cooktop with model # JGP933SEF1SS and the four igniters are constantly sparking even while the knob is in the off position or the on position, until I unplug it. There hasn't been a spill on the cooktop. I cleaned the ceramic igniters without any resolution. Would there be a problem with the spark module or harness switch? I appreciate your help.
  #24 (permalink)
Old 09-17-2008, 03:08 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The first thing I would check are the knobs. Pull them out, one by one, and check for any crack from the bottom where it's attached to the valve stem.
If there is nothing wrong then second failure suspect are the ignition switches. They are sold as a switch harness assembly which includes all switches in one harness. You can disconnect both harness terminals and check them for continuity. If the circuit is closed while all the switches are in the "off" position, then the problem is there.
If all of the above is good then the problem is a bad spark module.
- The part number for the knob is AP3427235
- The part number for the switch harness is AP3783914
- The part number for the spark module is AP3778816
__________________
  #25 (permalink)
Old 08-23-2009, 10:49 AM
Junior Member
PeterM is on a distinguished road
Default XL44 range igniter
I have a GE XL44 (JGB920SEC3SS) range. One burner's igniter won't spark, the other 3 and the oven are fine. The burners and base seem fine, and the screws are tight. The igniter tip looks like the other three. Ideas?
  #26 (permalink)
Old 08-23-2009, 01:42 PM
Junior Member
daveMess is on a distinguished road
Default
I have the same stove - with Kool Lite model 6544g10 ignitor unit - but the issue for me is my oven is not lighting cause the pezzo or whatever it is called has a broken tip - is that ignition lighter included when you replace the 6544G10 ?
  #27 (permalink)
Old 08-23-2009, 03:53 PM
Junior Member
Default More info on JGB920SEC3SS
I just swapped the left rear igniter for the right rear igniter. The problem remained in the left rear. So, the igniter is fine, it must be related to the wire, the connection or the actual igniter module. I don't see how I get to the part. Anyone know?
  #28 (permalink)
Old 08-24-2009, 08:19 AM
Junior Member
Default
My issue was the OVEN was not igniting - not the stove top - and when I took off the pan cover at the bottom of the oven I could look at the ignitor and see there was major deterioration on the ignitor - part no 12400035 - problem solved. And I am ready down the road for the next time - which will never happen cause I am prepared for it - it will obviuosly be something else.
  #29 (permalink)
Old 12-20-2009, 06:07 PM
Junior Member
vikkaraja is on a distinguished road
Default
Hello There, I am new here and I really could use some help. I have GE stove model JGSP23BEY2BB. Problem looks like is with the ignition module , but I would feel much better if you expert agree with me also. One of the burner does not lite occasionally and I have to use a lighter to lite it. I am not sure how it all started but I do have one of the rear burner left disconnected. Since one burner is left disconnected do you think it may be causing a problem for one of the other one not to ignite. Any help will be welcomed.Thanks.
  #30 (permalink)
Old 12-21-2009, 05:26 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
...One of the burner does not lite occasionally...
Does its igniter spark? Does it make a clicking noise? Would it spark if you turn on any other burner?
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Spark Electrode or Spark Module elpokeman Oven Repair (including Ranges and Cooktops) 0 10-22-2009 08:31 PM
spark module ernienorton Oven Repair (including Ranges and Cooktops) 0 09-18-2009 01:58 PM
didn't need spark module Ed S Oven Repair (including Ranges and Cooktops) 0 07-13-2009 01:19 PM
Viking Range stovetop will not spark Pat C Oven Repair (including Ranges and Cooktops) 0 03-11-2009 07:18 AM
Spark Igniter Module johnnyjohns Oven Repair (including Ranges and Cooktops) 1 01-02-2009 07:28 PM
