Discuss
GE Stovetop spark module not working
 in
Check if the cook top is properly grounded. Make sure all burners are grounded and clean from any grease. Make
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » GE Stovetop spark module not working
  #11 (permalink)
Old 06-07-2008, 06:02 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Make sure all igniters are not damaged and are in in the correct position in the flame.
Check all igniters wiring for damaged insulation.
Make sure there is no reversed polarity.
Ads By Google
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #12 (permalink)
Old 06-07-2008, 07:50 PM
Junior Member
BillSchee is on a distinguished road
Default
Thanks, Gene. I had not replaced the machine screws holding the burner "pans" in place because I didn't want to have to remove them again. I've now screwed them in place and it appears to have stopped the malfunction.
  #13 (permalink)
Old 08-02-2008, 08:33 AM
Junior Member
tabpilot is on a distinguished road
Default sparking at control module
Gene, I have a similar problem but at the spark module where the four wires from the burner controls enter, there is also a small metal plate separating 2 of the four control wires. A spark is jumping from one of the control wires on the left of the plate to the plate every 2 second. Do you think that replacing the spark module is a good bet to solve this. Thank you!
  #14 (permalink)
Old 08-04-2008, 01:35 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
tabpilot,
What is the complete model number of the unit?
__________________
  #15 (permalink)
Old 08-05-2008, 02:07 PM
Junior Member
Default
Gene, The model number of the cooktop is JPG336CEV1CC. The spark module is a kool lite 65644G10 which I replaced today but that didn't solve the problem of the spark going every 30 seconds. Guess I should be more patient. I check the things you mentioned above and it looks OK but will check again. Thanks.
  #16 (permalink)
Old 08-05-2008, 02:20 PM
Junior Member
Default
Gene, I wanted to add that the spark doesn't happen until I put the burner module on. Is this completing a circuit? Thanks.
  #17 (permalink)
Old 08-05-2008, 02:30 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Which part did you call "burner module"? Can you refer it to the break down diagrams, using a reference number?
Here are the break down diagrams for the GE cooktop Model JGP336CEV1CC
__________________
  #18 (permalink)
Old 08-05-2008, 03:56 PM
Junior Member
Default
Gene, the correct name is the burner head, part number ap2021339. When that part was put on the spark module started going on every 30 seconds.
  #19 (permalink)
Old 08-05-2008, 09:19 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
tabpilot,
You quoted me in your very first post. Did you check all these stuff?
__________________
  #20 (permalink)
Old 08-08-2008, 08:28 AM
Junior Member
Default
The burner bowles are clean as well as the buner heads. The parts below the glass level are also clean.
Igniters are in good shape and their position is correct.
The insulation is good. I see some discoloration on the plastic end where it plugs into the igniter.
The wires are in the same position as before and after the problem starting.
I'm not sure what to do at this point. The only thing missing are the paper washers for the screws that hold the burner bowls into the bracket bowl but it has been fine until now. I tuned all the burners on for about 10 minutes and after that the ingniter firing went from 30 seconds to about 5 minutes but today it is back to 30 seconds. I'm not sure if I should by a multimeter and check every wire? Any help is greatly appreciated.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Spark Electrode or Spark Module elpokeman Oven Repair (including Ranges and Cooktops) 0 10-22-2009 08:31 PM
spark module ernienorton Oven Repair (including Ranges and Cooktops) 0 09-18-2009 01:58 PM
didn't need spark module Ed S Oven Repair (including Ranges and Cooktops) 0 07-13-2009 01:19 PM
Viking Range stovetop will not spark Pat C Oven Repair (including Ranges and Cooktops) 0 03-11-2009 07:18 AM
Spark Igniter Module johnnyjohns Oven Repair (including Ranges and Cooktops) 1 01-02-2009 07:28 PM
